[ROOT] Virgin Mobile Security Update Now Rooted!!! Thanks jcase!!
Re: [ROOT] Virgin Mobile Security Update Now Rooted!!! Thanks jca
so I got all the way to reboot recovery (CWM-based Recovery v4.0.1.5 and try to install the jcase_rootme.zip but it says "E:Can't mount /sdcard . I previously had my SDcard partitioned with Lind2SD. I already tried moun /sdcard from the mounts menu. other options are mount /sd-ext and mount /system
Any ideas what I can do?
Even when you go to Install zip from sd?
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Help, a n00b (me) needs help. I keep getting stuck at the In -s permissions step. I've done a factory reset a couple of times, but it has not fixed the problem. Code from my terminal follows below. I used adb. Thanks a bunch to this awesome community!
C:\Android\android-sdk\platform-tools>adb push flash_image /data/local/flash_ima
ge
1107 KB/s (9640 bytes in 0.008s)
C:\Android\android-sdk\platform-tools>adb push VM670NH_recovery.img /data/local/
2941 KB/s (4200448 bytes in 1.394s)
C:\Android\android-sdk\platform-tools>adb push jcase_rootme.zip /sdcard/jcase_ro
otme.zip
4113 KB/s (640406 bytes in 0.152s)
C:\Android\android-sdk\platform-tools>adb shell chmod 755 /data/local/flash_imag
e
C:\Android\android-sdk\platform-tools>adb shell rm /data/amit/*
C:\Android\android-sdk\platform-tools>adb shell In -s /dev/mtd/mtd2 /data/amit/A
MI304_Config.ini
In: permission denied
This may sound crazy, but double check you are typing all the letters correctly on that last command you are getting hung up on.
Should be adb shell ln (being lowercase L and lowercase N) and then AMI304 (being capital A capital M capital I).
Took me a few minutes to figure out which was which and I actually had to compare with Xda forum to be sure.
No idea if that's the problem, just thought I'd mention it.
Edit: Got ninja'd by dennyc23 ;)
ge
otme.zip
e
MI304_Config.ini
I just copy&pasted your "ln" into the Google search bar, easiest way I know to check letters due to the auto-search feature. You typed I (capitol "i"), and it should be a l (lowercase "L"). ;)
I created a "oneclick"... well not really one click, more like idiot proof, that will do the steps outlines above for you... It can be found HERE
You will have to scroll
I wuv you dennyc23 and JerryScript! I am happily rooted! Cue the Gospel song "Freedom!":)
i stumbled out of it thankfully. i unmounted all the sd options and then mounted sd card again. Rooted again. Whew. Appreciate the help
Now to figure out how get all my old apps back working again with link2sd. I remounted but nothing really happened. If i reload titanium backup, can i just restore the apps?
Hello,
I was wondering if the very first post in this thread is the most updated guide for this root or should I read through the entire thread for various updates and ideas?
Thanks
Hello,
Thanks
The first post is completely up to date and works perfect so long as you have already done the security update from Virgin.
Just make sure to read all the steps carefully.
Can someone please help, it keeps booting into CWM-based Recovery v4.0.1.5
At what point? What have you done already???
I was attempting the Gordita1Click, it all finished but I wasnt rooted so my plan was to factory reset then try again. When it rebooted it got stuck in this loop. I believe I do have adb access.
deleted
Oh I'm not familiar with the one click method of this root. I'm sure someone will be able to help you out though if you hang in there.
Oops, sounds like the classic no-no: Never use factory reset in the privacy menu after a custom ROM is installed. That command relies on the stock recovery to complete. Lots of people done it, it's one of the first rules after you root your OV and flash a custom recovery: Only use the factory wipe in the recovery menu.
Check LeslieAnn's 2012 Reference Guide to the OV under stickies in this forum. I believe it has the steps (and/or links) to get you back on the horse. There are also many other threads on the subject. I haven't done it myself, so I'm afraid I have no first hand experience.
Edit: Just saw riggerman's post. Yes, of course, now that we have VMU update.zip (AND Gordita root), simply running that is an easier way to fix bootloop issues -- assuming you can boot recovery.
I have searched and tried everything I have come across, no luck. I think its dead :(
If your in the recovery, try to install the update. Click on install update, let it install and it should reboot you back to stock with the stock recovery. Then install the update again from the stock rom.
It installed the update.zip but still booted into cwm recovery after
gruptysh
