Running Flash well on KitKat?
I would raise a glass to the dev, but i have no glass. So i will just smile 🙌
Epic workaround, just shows how awsome some people can be when they get their hands on the important code and a code editior.
I would raise a glass to the dev, but i have no glass. So i will just smile ��
Now all we need is for someone to make this work with Firefox.
Quick question,
Not like i care,but is this modified flash player going against some murky terms and conditions?
What if i told you
android is superior to ios
Unable to install flash version mentioned in this link, it says that - an application with same name having conflicting signature is already installed.
This message comes even though I have uninstalled existing version from tab as per this link. Any idea how to over come this error?
Sent from my Nexus 7 using AC Forums mobile app
I had the same conflict problem. went to settings/apps/all and uninstalled whatever flashplayer showed there, reinstalled this one and it works fine now.
Currently I have not seen anyone get it working on 4.4. Its taken out of the AOSP browser as well.
Adobe does not support android 4.4 kitkat to have adobe flash player as a native system feature but flash can be installed manually on android 4.4 kitkat. Android 4.1, 4.2, 4.3 Jelly Bean users can also install flash manually .
Go to Settings > Security > Check Unknown Sources.
downloade the APK file on your computer, copy and paste it to the internal storage or microSD card of your Android device.
tap the APK file to install Adobe Flash on your Android Jelly Bean running device
go to your mobile browser and enable Flash from the settings option.
heritagevines36
