RUU 2.07.605 vs. RUU 2.10.605
I've seen a couple people saying the mobile hotspot was working. Are you subscribing to it or is it coming in free?
I also noticed the handoff is quicker in 2.10 from 3G to LTE. The notification bar switches icons instantly. Previously, the 3G icon would disappear for a second and 4G would show up. There's now no delay.
I have a unrooted phone with unlimited data no mobile hot spot its coming in free. Wow, is there any risk to using this feature?
Sent from my ADR6400L using Tapatalk
Its been talked about when it first went away and people were still getting it for free. Verizon can and might try and bill you but it wouldnt be that hard to say that you were never told it wasn't free so they'd let it go but obviously after that, you couldnt use it anymore.
-Frank
Now I am not sure I remember this, but can anyone with the 2.07 go into Settings -> Power and tell me if the top option is "Enable Power Effeciency"?
I do not remember having that on the 2.07 ROM, and know for certain it was not on the 1.70 (MR2) ROM.
For anyone that cannot see it, its a check box that, once enabled, will disable mobile data and turn off auto-sync. Awesome way to save on battery, but to be honest it is not as good as Juice Defender on Aggressive mode.
A power saver option was on 1.70 if thats what you mean. Looks like they just renamed it. the Power Saver settings are like you describe. Turn wifi bluetooth etc off when the batter reaches a certain level
No, Power Saver is still there with all its same options. Power Effeciency is a new option that is a simple check box on/off. No other options associated with it.
See?
You can also see in this image some of the ghost images I get in the notification bar.
Ahh I gotcha I guess I read it wrong it sounded like maybe they just renamed what was already there. What does fast boot really do for you? I dont have that on. Also what does assisted dialing do and is it needed?
See?
I do not se it on 207
Have there been any reports of apps not working? Is this update worth doing? Any opinions are greatly appreciated.
I think its well worth it although I use Google Voice for all calls voicemails and texts. I noticed a slight speed increase in navigating the device with this leak over the first leak.
I haven't noticed any real comments regarding battery life. Anybody want to chime in please? Its important to me before loading this or not. Compare it to stock and the two leaks, if anyone would please?
Well I don't know about 210 battery life, but 207 I have been on heavy use mostly WiFi but again heavy use and lasted about 12 hours until i hit orange on the battery.
RichardDixon
