S III Battery life...
The battery life on this phone is terrible! I LOVE the phone...don't get my wrong...but good lord! My phone was @ 60% when i fell asleep last night....i woke up.....and my phone was DEAD. 0%. WTF? :-:-\
Someone please help!
Did you have the stock music player running before you went to sleep? I have found that if I don't kill the apps in the background it will kill my battery quick. Also are you using power saving mode?
I am impressed with the battery life of this phone. I have only had it for 5 days but it's getting better with each charge.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Now that I manually sync my mail, battery life's much improved. When I'm out for long periods and I'm concerned, I use power saving mode. Makes a big difference too.
I wish this phone could get that type of time with actual usage, that would be awesome, but good standby time none the less
sent from my Samsung Galaxy S III on T-Mobile! goodbye Sprint!
My battery is total garbage. I charged all night, pulled it off the charger at 0800 checked emails and browsed for approx 10min, left it alone until about 1015....65%. It seems like t used more idling than when I'm browsing/using it. Currently at 54%. Screen brightness around 30%, ALL power saving modes on. WiFi here at home and I'm usually on 4glte.
HELP!
Noticed the same battery issue initially. I took the advice of a previous post which suggested: after charging overnite, remove from charger, then when battery shows approx 88-94% plug it in again until fully charged. This has helped immensely! I can actually get thru the day without the "low" warning.
I also noticed the battery is getting better with each charging cycle.
Reactions: GuilderlandNY
...for the past two days, something has been killing my battery, quick. I think it might be the weather widget. I just put it back on my main screen a few days ago. Albeit, the update was set to three hours!
Anyway, I've removed it, and gone back to just a clock widget.
Also, I installed Google Reader and Google Voice this week. I think I'll uninstall those; not like I use them anyway, and we'll see how the battery behaves.
...something is seriously wrong with the battery life on Samsung device(s). It has been this way for a few days now, and various users, and various Samsung devices(s). I bet an update to an app is causing this.
Today I woke up to a dead device, after going to bed with it at 78%, and NOTHING was running in the background.
I just did a factory reset, and now I'm at 100% (11:05 EST). Let's see where it is when I leave the office around 16:00 today.
Anyone else?
Mines been pretty good so far. I've had it last upwards of nearly 30 hours before. Screen time on this one was a little over 5 hours.
My battery life is just awful. Down to 18% this morning in about 4 hours from fully charged! What would be making my "Android System" drain so high??
Also, no way to upload a picture directly here, must put it somewhere on the web first?
Sorry but ima Android noob come from Apple...I'm scared to remove or stop thing from my applications because I don't wanna remove something important...how do I disable thing running in the background and what stock apps do I need to keep running
5 hours?
I've never had more than 4 hours screen time out of this phone.
Screen time is the reason I say if you really use this phone it won't last all day
Sent from my htc_jewel using Tapatalk 2
I'm running Juice Defender, the weather widget is set to refresh every 3 hours and right now, the charge has lasted over 19 hours with 51% charge remaining. Granted I'm not a heavy user and also am on WiFi while at home. I also work from home and there aren't many LTE towers yet in the SF North bay, though tons of HSPA+.
I suggest anyone having battery issues makes sure they do the battery calibration described here: Calibrate Android Phone/Tablet Battery and Achieve Longer Battery Life I did this when I first got the phone and one charge before using the phone a bunch I ran well over 36 hours before needing to charge again. Juice Defender seems to work great too, along with power saving mode in settings.
I've noticed that if I have bluetooth and wifi on all the time I get the same battery life as with them off. I'm at about 40% by the end of the day with moderate to heavier use. Brightness at 50%. I'm happy with that. No third party apps.
Something is killing my extended battery.how funny does that sound !!!!!!!!!
It's not that battery because I switched with my husband and its sit the same, and his phone is still at 80% from this morning.Mines is at 48% it's only been like 6 hours
Just started happening last week all of a sudden.
~Jae, Tap'n on my White Samsung Galaxy S3~
Gsam battery monitor should show what's eating it
---Sent from the most advanced android mobile super-computer on the planet: the Samsung Galaxy S3 on AT&T, featuring simultaneous voice & data and speedy 4G!!!
I've had that installed for weeks now
jeffnachatilo
