- Feb 6, 2017
- 99,140
- 15,858
- 113
Last oneYeah that’s where I got it from.. which one should I choose. Thanks again
3.14.1 3b patch
Should , let me knowIts loading right now so hopefully this time it takes it..
It wont show Verizon or any carrier on unlockedCrossing my fingers lol it didnt go to verizon boot loader.. its at the optimizing apps part so it looks like it took it LOL
Perfect, your welcome!It took it lol and now it has 5g! Thank you so much man!
Good, your very welcomeIm good with this, thank you again sir! Have a good night!
Can you change to English the screen words? , I can help you , also you buy this phone new ?Hello my phone is unlocked sm 988u s20 ultra i cant take ota updates now. When i push check updates it says your software version doesnt supported. My firmwares are messy i dont know which firmware should i flash can you give advice to me?
Sofware Update Check Page: https://imgur.com/a/Ozif6Eh
Device Code: https://imgur.com/a/UH48TTH
Software Informations: https://imgur.com/a/RXNE3Tc
Smart Switch Page: https://imgur.com/a/1y2a9BR
I'm not sure what happened, I dont think the seller messed with it .Yes. The seller said this phone came from us. And maybe he flashed something different for software. by the way i flashed the firmaware that i put on previous comment from sammobile and it works. What do you think why my software was so messy
