- Feb 6, 2017
- 97,744
- 13,807
- 113
I haven't heard anything yet from their dicord channelYea, I was wondering about the official public release/update like from the Playstore?
Yes it doesDoes Samsung gesture place nice with Nova? I don't want it to explode.
Nova is fir users that more customization then the stock launcher so in your case you probably dont need it .Anyone have an opinion on my question above?
Yeah most likely , but if you like more customization then definitely the launcher to use .Ok thanks. I tend to believe it may go underutilized with me.
I switched back to the 3 button nav bar and am slowly getting used to using it again. The only thing I miss is the swipe to go back. It's way more consistent than gestures, especially with a case on my phone.
Dude! Thanks so much. I missed the swipe to go back gesture.My dude...
It is amazing that some people here use gesture and don't notice the Android bug....
I don't even know what to say about that.
Anyway, there is an app on play store, by Samsung, called "onehand opetaion plus."
It let's you have swipe from sides to perform BACK action.
Try it. It is what toy want.
In combination with the 3 button up swipe gesture mode, it is the best till th flicker bug is fixed.
You have issues with Google gestures with swipe on side screen to go back?My dude...
I did have that flicker early on in Android 10 when it came out but over updates and android 11 it didn't happen anymore but I'm also using Nova 7 betaNo,
I have issues using 3rd-party launchers, namely Nova, (any version), on Galaxy S20 / S21 on Android 10+/
Just as described earlier in this thread.
- Enable Nova
- Enable Android Gestures (swipe from bottom for home/assitant, swipe from sides for back, swipe bottom to the sides to switch between apps)
- Try to use the phone, after certain swipes, the UI flickers and is unresponsive for a moment until it is re-drawn.
To Workaround this annoying bug, specifically on One UI 3.0, I enabled using 3 swipe up buttons mode, but then I really miss the swipe from sides to go back.
To work around the lack of back gesture, I installed OneHand plus operation.
Yes , I will try later onI am almost in disbelief hehe.
And I envy you.
Can you screen record?![]()
