S22 Ultra Battery Poor
I get around 7-730 hours SOT from 100%-20% on my S22+. There are so many apps you can turn off and disable from running in the background. It makes a huge difference. I also use either Facebook Lite or just a Chrome link, and uninstall the main Facebook app and disable all of the background stuff.
Yes!!!! I don't use the FB app at all. Just sign in through the browser and sign out when im done and close that tab. That's helped a lot as well.
I use Facebook, telegram, Instagram, whatapp no tweaks and left the screen resolution at stock FHD , I wonder how crazy good it be if I didn't have them from already great battery life
Not true well for me it isn't i get 10 to 12hrs SOT on my AT&T S22 Ultra 5G Snapdragon 512GB Screenshot_20220421-063148_Device care.jpg
I just noticed my S21 Ultra was on the wqhd plus and then I looked at this phone and it's on FHD and it said if I change it it could use more battery. But my screen looks good to me I like it I couldn't tell much difference looking at both of my phones. And I probably need to turn off some background apps too but my battery has been okay for me. I mean I've never gotten over a day I always end up charging it after an 8-hour work day I come home with about 30 or 40%, I was on 60 tonight.
Just seen your other post lol
I noticed something that some of you may have noticed as well.
I went to Battery and Device Care-->Battery-->Background usage limits-->Deep sleeping apps.... I tapped the plus sign '+' and tapped 'All next to 'Select Apps'.
My Battery life has subjectively increased quite a bit. If an app needs to come out of Deep Sleep it seems to do so by itself yet the increased Battery life remains great. ...and this is with Adaptive Refresh Rate and WQHD enabled.
Seems I've found/confirmed the trick works for me so I wanted to share.
I always have that disable, i never let my apps go to sleep or deep sleep, and i Still get 11hrs SOT on my S22 Ultra 5G Snapdragon 512GB
I guess it also depends on the apps and how much they like to do in the background too.
So if you put them all in deep sleep when you open one to use it will come out of deep sleep? Was just wondering if I should try this and see if I notice a difference in battery. My SOT averages 4 hours and something maybe 5 one day within the past week I had 6 & 1/2
So if you put them all in deep sleep when you open one to use it will come out of deep sleep? Was just wondering if I should try this and see if I notice a difference in battery. My SOT averages 4 hours and something maybe 5 one day within the past week I had 6/12.
Yeahp. It's easily reversible so you can safely give it a try.
I only got 4.5 hours of SoT from 100-0 in the week I had the S22 Ultra and that's why I returned it. If it would've had great battery life, like what I get for my iPhone 13 Pro Max, it would've been he perfect phone.
I think chrome is a battery hog also
Actually it is always battery hogger so i disable it plus Chrome is garbage i use Samsung Internet, best browser.
Facebook is another battery hogger so i don't use it since it's garbage as well.
Ashok Dharshan
