s7 edge 7.0 beta thread
I have had similar issues with what's app on nougat. On a few occasions I have had a message that has had no notification on the phone and I only find it by opening the app. However this has happened maybe 2 or 3 times and the rest of the time it works great
Wondering if it may have something to do with data saver and restricting background data maybe? I just set whatsapp to unrestricted and it all seems ok again.
Fyi after the update battery was bad for a couple of charges.....but no at its 3rd full charge battery seems to be better than on marshmallow
Is multi-window wonky for anybody else? It seems to the buggiest thing I've found so far.
Seems to work fine for me although I don't use it often. Often get a pop up saying the app may not be supported but then it works anyway
T-Mobile s7 edge beta download?
Would anyone happen to know if there's a copy of the nougat beta for T-Mobile that I could download somewhere floating around? I keep checking XDA but it's like a jungle over there trying to find something lol. Thanks
I rarely use it as well. Maybe it works a little differently than Samsung's implementation or I'm forgetting how to properly use it. It just seems to feel odd to me.
I think they've adopted Googles way of doing it so it is different to how it used to be
Anyone else have the galaxy app store gone from there phone after the update? Verizon gs7 edge.
It's gone after the update, unless you do a factory reset and it will show up. There is a galaxy app widget you can use without doing a factory reset.
Has anyone noticed an issue with apk files since the beta update? My S7 Edge will no longer install apk files.
Go to your settings, scroll down to About Device, click on Download Updates Manually, if you were selected to be a tester then the download will appear.
Galaxy App Store is still intact on my T-mobile beta as well. However I did have problem where my phone suddenly went blank. For a couple of minutes I thought the phone was bricked but it finally restarted. Whew!
I don't see this option on my Verizon s7 edge. I successfully registered for the beta a few days ago and still haven't got the update
Then Google how to check manually for updates on verizon's S7 edge, that should help. The software update won't appear on your phone automatically, you have to actually manually check for it.
Taylor Bag
