Samsung A10 Pin required after factory reset
Status
Not open for further replies.
FHPavil44
3
I have a Samsung A10 and after performing a factory reset it is still asking for a ping to continue setup. I can't get past to get to settings.
fuzzylumpkin
5,555
2,558
113
Yes, I went into the boot menu, not android, and Factory reset. I even wiped cache and performed another factory reset.
The question was WHY did you factory reset..
But this is probably factory reset protection... you have to enter the old PIN or remove the phone from the original Google account in order to prove you didn't just steal someone's phone and factory resett it.
fuzzylumpkin
5,555
2,558
113
That's that then. You can't use it.
Only thing to do is return it to your employer and let them know. If it's a managed device, the IT department should be able to remove it as administrators. If it's not a managed device, I hope someone needs a paperweight lol.
Status
