Samsung A51 Restarting On It's Own - Please Help
Esma Graham
79
Samsung A51 Randomly Restarting on its own
Auto Restart is turned off
Have done a Factory Reset through phone and through bootloader
Have wiped cache through bootloader
Have done a Reset Network Settings and Reset Settings through phone
Bixby not on home screen or side bar but still using Storage
Gone to Mobile Klinic where they done a force update and rebuild of android
And it did again last night a few days after they did it
Please Help me with this issue
Hi,
When does it auto restart? Is there a exact time or is it happening often as your using the phone
Tuesday and Thursdays it seems like it does it.
The phone is no where near me I pick it up and it says "Phone is starting" like it just restarted on its own
Haven't seen it actually do it other then the once it did it on a Tuesday where it restarted on its own no where near me.
I got this phone less then 1 year ago
Does it seem like it happens at a specific time, or is it just at a random time of those days?
If feasible, try using your phone in Safe Mode for a few days and see if it still restarts. https://www.hardreset.info/devices/samsung/samsung-galaxy-a51/safe-mode/. You won't be able to use any of your 3rd party apps that you installed, but this is the best way to start narrowing down the problem.
Do you use Bixby routines?
The issue with Safe mode is i can't re-create the issue it just happens on its own
Using it for a few days in that mode I will be unable to talk to my boyfriend who's in a different city then I am right now on WhatsApp I kinda need access to the phone.
It just happens at a random time those days and ever single app that I have is from Play Store or Galaxy Store for the galaxy apps like such as Samsung Cloud
No but it's still using storage on my phone
I use this app to disable all those things
https://www.packagedisabler.com/
That app is to disable those bixby from running in background. But yeah let's see what happens, it did it only once ?
No 4 times in total including yesterday
The 8th, 15th, 17th and the 21st that I've seen it do it
Also my phone does weird things like sometimes going into messaging to send a text to someone it will say "Welcome to messaging" like it did a reset or something even though i used it less then 10mins ago.
Screen will flicker so I might take it to Bell MTS tomorrow to see if they can figure out what's going on or give me a new device.
Oops, sorry about that!
What's the battery level at when this happens? Do you notice the phone getting pretty hot when it happens?
Oop, sorry about that!
Not even using the phone when it happens
Phone has been no where near me when it happens
Has been about 80% at least 2 times and other times about 40%
Yeah get it checked out , maybe you have warranty still ? Screen flickering something going on , was phone dropped hard at all?
Lelix2603
