Samsung A51 Restarting On It's Own - Please Help
Esma Graham
79
Samsung A51 Randomly Restarting on its own
Auto Restart is turned off
Have done a Factory Reset through phone and through bootloader
Have wiped cache through bootloader
Have done a Reset Network Settings and Reset Settings through phone
Bixby not on home screen or side bar but still using Storage
Gone to Mobile Klinic where they done a force update and rebuild of android
And it did again last night a few days after they did it
Please Help me with this issue
Ok let them check it and maybe get it warranty, that case looks pretty good for small drops .
I will as they said yesterday they could do a replacement but the tech would have to look at it first
What would be a better case for this in the future?
I've heard good and bad things about outterbox
That app is to disable those bixby from running in background. But yeah let's see what happens, it did it only once ?
First Question
While using my phone sending typing a message to a friend of mine my Phone screen went black then came up with the Samsung Logo on it like the phone had just turned on.
Second Question
Why is Bixby still using data with the package disabler
Samsung A51 Screen Goes Black Then Starts up while using it - Please Help
So I recently got the Package Disabler Pro (Samsung) for my phone and disabled Bixby from the background yet it is still using Data
As seen in this image - https://imgur.com/a/dFW8eaT
While using my phone today and typing a message to my friend my phone screen went Black then came up with the Samsung Logo like the phone had just turned on this happened while I was using it.
Have done a Factory Reset through phone and through recovery mode
Have wiped cache through recovery mode
Gone to Mobile Klinic where they done a force update and reflash of android
Please help me with this issue
First Question
Second Question
Enable developers settings check running applications , its not running
As for staying on the Samsung logo , if you have warranty let them take care it.
Its not staying on that screen I will re-phrase it
I was typing a message to my friend on WhatsApp and then my screen went black randomly then the Samsung Logo came up like I just had turned on the phone even though I was using it
I am currently using the phone right now and watching Tiktok on it
You didn't experience this prior the mobile clinic flashing your phone ?
Not while using it no ........... Do I know if that's what it was doing when the phone was not near me? No
They ran a Diangosis like a few days ago after I installed the Package Disabler Pro the one you told me to get
After they gave me my phone back I seen the Bixby in my button order after them giving me back my phone i had to restart it twice for the Bixby in my button order to vanish
Why did they flashed the phone ?
If they flashed the phone , that would reset everything and you would have to disable Bixby again.
Through there computers somehow with Samsung website idk how there trained to do that they told me I would loose everything
And that was before I had that App you told me to get
Ok gotcha, thought something you did just recently. I'm familiar with how they do that, as I offer help here in forums for flashing Samsung phones . What they didn't know was you can save data when u do flash, but thats ok its been done.
Thats a major crash from texting and went to Samsung logo , try get your device fixed under warranty , you been through lot different try this try that.
Kinda sucks I don't have a spare phone and the best they can give me for loaner phones with be an S5 from Cell Mechanics or an S6 from Bell MTS and I need Facebook, Facebook Messanger, Whatsapp at the very least while my phone's being fixed
Can you get something like Motorola like 250 or maybe another android for 180.00 , I know it not good situation to buying and being without a phone for little.
Yeah unfortunately I live on a Budget of so much per month so I couldn't afford $180.00 right now
Even paying $100.00 for another phone or even a tablet to put the sim card into that I'm going only need for 1-2 weeks isn't worth it in my opinion.
Yeah unfortunately I live on a Budget of so much per month so I couldn't afford $180.00 right now even paying $100.00 for another phone or even a Tablet to put the sim card into that I'm going only need for 1-2 weeks isn't worth it in my opinion.
This crash when texting only while using whatsapp?
Its the first time I was actually using the phone while it happened so I'm not sure
I use WhatsApp every single day so I highly doubt it would be that
When its happened when it's no where near me all apps have been closed
Try monitor in safe mode , yes it will disable 3rd party apps but see if it happens again.
With it not happening every single day that would be hard to do as I need apps like Facebook Messanger, WhatsApp and stuff to talk to my boyfriend who lives in another province right now
I also had WhatsApp on my Samsung J3 that I had years ago never had this issue my only issue with that phone was it restarting itself with any bumps I would be on the bus that bus hit a bump and the phone would restart
No Different App's from that phone to this one other then the one you told me to get
slackingfred
