Samsung A51 Restarting On It's Own - Please Help
Esma Graham
79
Samsung A51 Randomly Restarting on its own
Auto Restart is turned off
Have done a Factory Reset through phone and through bootloader
Have wiped cache through bootloader
Have done a Reset Network Settings and Reset Settings through phone
Bixby not on home screen or side bar but still using Storage
Gone to Mobile Klinic where they done a force update and rebuild of android
And it did again last night a few days after they did it
Please Help me with this issue
I still have to call the lady later today and that gives this phone more time.
As it might been a glitch as it happened while I pressed the back button on Friday.
The back button that's at the very bottom layout of the phone underneath where you type of the keyboard that one.
ODD Question shouldn't my IMEI Number be different with a New Motherboard?
Cause according to the Sales paperwork and IMEI Number under about Phone it looks the exact same.
Actually the answer will be a no if done through a Samsung certified repair. I know this since there is an old school hack with coding and it's fairly easy to do. Illegal for the consumer but legal for someone like Samsung to do...;-)
Samsung Package Disabler Pro is no longer working for me since its no longer on the Google Play Store Anymore
What can I do now?
Every time I open it i get this
"Failed to Validate the Product Key"
Yeah another member has same situation, contact the dev , you didn't purchase from website?
Have to contact the dev , that blue I think is for older android version, need to have the green like mine , let me see if I can find its apk
Ok , I'm curious what they say , I'm waiting on another member that did the same.
Copied from my e-mail from them
Hi,
Samsung blocked our play store app so many times. So each time we republish the app in the play store, the version number has to be changed. But don't worry, both the apps are same in functionality, only a minor difference in UI.
Regards,
PD Team
Edit - Weridly my phone hasn't restarted since i did a factory reset through recovery mode then installed that app right away before I would do any updates through Play Store or Galaxy Store
Hi,
Regards,
PD Team
Umm how did Samsung block their play store app ,only Google can do that ?
lilyo7788
