Samsung call and text on other devices for Verizon note 10 plus
Do it through Samsung smart switch on PC
what link do i need for odin could not find it on google
This is the steps :
Windows computer needed
Latest Odin can Google it and download should be 3.13.1 prince comsey. Samfirm/ or Frija tool
Download samfirm v0.4.1 tool , extract it with 7zip. After open the tool and put SM-N975U1 firmware with xaa region download to computer
You will extract files for Odin once download with 7zip and will do same for firmware with 7zip .
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
Home data slot dont put nothing
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
Put your model number,region select check for updates , then download the Rom , extract the Rom with 7zip.
*Make sure you put phone in download mode
*If dont see your phone connected in Odin change cables or ports in computer .
Use Odin v3. 14.1 patch file
Frija: use latest file
Use model number for unlock which is a "1" at the end and any CSC like XAA /Tmb/VZW
This for fija when download the firmware
Make sure known good cable( very important)
Phone in download mode
Once you extract the firmware zip open Odin and put in corresponding slots except CSC use firmware Home CSC and user data empty
It failed
RangelS25
