Samsung Galaxy Note 4 Fingerprint sensor working better than expected :)
Beltelmel
102
I have been using it on my lockscreen and it is working pretty damn well! Took a couple of days of trying but I seem to have gotten the right swiping tempo where I now rarely have to swipe a second time. (Knock on Wood).
Re: Fingerprint sensor working better than expected :)
I hated it on the S5 that I'm afraid to set it up. LOL
I tried it multiple times and even watched YouTube videos for tips and was still only at 60% success rate.
I was busy with work all weekend, I'll give it a shot tomorrow.
Sent from my SM-N910W8 using Tapatalk
I think it helps to be imaginative when setting the 10 scans. Use every angle and a couple times you think you will use most. My scanner is as easy as the swipe, it is simply on another part of the screen and with a little finesse.
It actually works pretty well. Sometimes I forget "how" to do it, but once my muscle memory kicks in, I will get it on the first try all the time.
I've mentioned it in several other threads that talk about the scanner. my finger print scanner works flawless.
girls love tech too
I had the finger print lock screen enabled but disabled it and went back to the no security swipe screen I typically use. The problem was not the effectiveness of the finger print scanner... It worked fine. The problem was me. I never fully realized how much I use/glance at my phone at odd angles until I had to scan my finger print in a particular direction to unlock the device.
I would say it works a solid 90-95% of the time pretty good imo
Hated it on the S5, gave it another shot on the Note 4 on day one and haven't shut it off.
Huge improvement.
after all the negative comments, I was prepared for the scanner to really suck. Decided to give it a few days... the first day was difficult but after that I rarely have an issue. The wife has an iPhone 6 and she has about the same level of issues (only once in a while) as I do with the scanner on the Note 4.
Pleasantly surprised.
I've been very pleased with it. It's my first experience with a fingerprint scanner and I've been pleasantly surprised with the success rate.
Sent via Tapatalk on my Samsung Galaxy Note 4
The scanner works 90% of the time for me...I would be happy with 75%...I have both thumbs scanned
Note 4
I don't like it. I won't be using it much at all.
I hated it at first. I guess I was setting it up wrong the first day I tried it. I read the other post on it and paid close attention to the demos on the Phone, and figured out how to get the fingerprints registered. Was getting a lot of errors the first time about not hitting all of the button, or not a match. Tonight got it right and now it works most of the time. I think it's just getting the technique of sliding you finger down. Not bad now that I'm using it correctly. Time will tell if I kept that or not. I do like to just swipe the screen.
Wish I could figure it out. It frankly drives me insane...when I register my thumb(s) everything looks great but when i try to actually unlock using my thumb I get like 5% success rate. It says..."slow down", "faster", "middle", blah blah blah. The touchid iphone 6 and 6+ I tried for 2 weeks basically worked perfect w/about 99% success so I don't know what's up.
Maybe I should take the case off? try try again
It would be nice if you didnt have to swipe your finger; I can only get it to work about half the time. I wont be using it.
Works perfect with my Right index finger. My Right Thumb is giving me problems. I have re-trained it several times.
the scanner works most of the time For me. you Just have to register your Fingerprint at different angles
Mine doesn't work the first time every time but a lot of the time it does. I like it a whole lot better than entering a 6 digit code especially in the car.
Does it drive anyone else crazy get the:
You have incorrectly attempted to unlock the screen 1 time. If you attempt to unlock the screen incorrectly 4 more times, your backup password will be required.​
After receiving that message, I don't even get to make a second attempt (which believe me is required often on mine), I have to now look at that message and touch on 'OK' to dismiss it and now try again. That is fueling my frustration with the fingerprint scanner. Is there a way to turn off that message?
I love it, it is working very well for me. Had issues at first til I learned to use the same swiping motion all the time. Now I barely have a fail.
04ijordan
