Joe_Perone
- May 21, 2013
- 227
- 0
- 0
After a few charge cycles on 4.3, here are my results from this morning. This is unrooted, with wifi and data usage through the day, and about 2.5 to 3 hours of talk time as well.
http://i.imgur.com/zpfifEB.jpg
http://i.imgur.com/ra6EFUO.jpg
Anyone have any recent experience with the Battery Guru app? Just curious if anyone has had any real success with that app.
Well I'll post my screen on time before I charge my phone at the end of the night. I'm pretty sure my screen on time was around 2.5 hours as well. Some may be using bigger battery and not the standard 2600 mAh battery. So that may be one reason why others have such a higher usage time. I'm sure there are a lot of factors to why it brings up higher screen on time and with good usage. I'm pretty sure listening to music on the phone will do just that.
I don't know if it's anything related to it, but 2 days ago I got a Firmware Update saying ( fixing some stability issues ).
1. Last night I played with Buzz launcher trying to make a nice screen, and I had the screen set to maximum Brightness. MY phone was about 80% when I started it, and I by the time the battery went down to 25% I already had 4 hours and 48 minutes of ON Time. Which is so far the best I ever had. and that's just by using 55% of the battery. I could have probably hit 6-7 hours.
CONDITIONS: Max Screen Brightness, Strong WiFi signal, Some Chatting on LINE, and downloading tons of Homepacks from Buzz Launcher. ( DIDN'T Play and game )
2. Today
From 95% to 20% in 6h31min ( on time 2h55m )
CONDITIONS: Auto Brightness, 3G poor signal (1-2 bars), a lot of LINE / Mixi chatting, email sending, 50 minutes of Voice Navigation usage
Seems to me like the biggest battery killer after the screen is the mobile connection. If the signal is weak, it rapes your battery. Does it even show in the battery stats?
But still I got better usage time than before. Did you guys get the update? Could it be that they improve the battery lifetime in the last small update? it was about 120MB.
2. Today
That sounds unrealistically good for auto brightness. I have hit 6/7 hours but have auto brightness about half the time and almost at the lowest for the rest of the time. Is this the stock battery?
Yea it's stock battery. My model is SIM Free GT-I9505.
I usualy get 2h -2h30m ON TIME with lowest brightness possible. 3h would be something really rare... but since last night it seems to last longer. Could it be the update?
I also downloaded Snapdragon Battery Guru, but it has 6 more hours of learning.
( I have location on, google now on, most of the smart features on, except for the eye scroll thing. The galaxy browser is slower than chrome, so thre's no APP i can use it in )
I will make a full charge now, and use the phone till it hits 1% and I'll post an update again. Maybe I was dreaming last night, because it sounds too good to be true.
Battery dropped from 100% to 80% in 58 Minutes -----> almost 20% by hour with screen ON.... so I'm guessing i should get over 4.5 hours. I wonder if the ratio stays the same if I use WiFi instead of poor signal 3G.
Hey Grants,
What is Snapdragon Guru? Are you rooted?
What are the %s of the things using your battery?Right now I'm at 50 percent with 13hours and screen is on an hour 25 minutes only. Alot less than most of your reports. I don't use the screen stuff and the brightness is very low.
