Samsung Galaxy S4 cannot connect to PC via USB after upgrade to Android 4.3
The code *#0808# brought me to a USB menu. I selected MTP+ADB. When I plugged my phone into the USB port the driver installed (correctly this time) and the USB symbol appeared on my notification bar. Opened "My computer" and the phone showed as a device! I was able to transfer photos off the phone to my PC! Thank you! Thank you! Thank you! :)
Samsung Galaxy s4 ATT i337 connected to Win7 PC
I dialed the code *#0808# . Brought me to a USB menu. I selected MTP+ADB. When I plugged my phone into the USB port the driver installed (correctly this time) and the USB symbol appeared on my notification bar. Opened "My computer" and the phone showed as a device! I was able to transfer photos off the phone to my PC! Thank you! Thank you! Thank you! :)
thank you so much i have spent weeks pulling my hair out trying to figure out the problem i have just followed your instuctions very strictly and now my problem is resolved i cant thank you enough
Hi,
I'm just correct this issue with this code on my s4 in version 5.0.1 : *#8080# , i define MTP+ADB reboot, now recognize on my windows 10 with a lot of usb cable.
Thanks
Hi, I rebooted my phone as you instructed but when I connected my phone to the laptop with the usb cable, nothing happened =( My S 4 is 4.4.2. Please help me! =(:'(
Re: Samsung Galaxy S4 cannot connect to PC via USB after upgrade to Android 4.4
for Android version 4.4 solution is ...
need disable DM option on hiden menu ...
Open the keyboard and enter
## 366633 # is enabling download mode (allowing ports to open for modem)
i when selected another option DISABLE DM and problem solved ;)
Made no difference for me. Still doesn't see the phone. Also tried the suggestion for *#0808#. Doesn't bring up a USB menu.
I'm confirming this. Switching the cable to original cable really worked. Managed to solve both my floating notification problem and usb connectivity problem. Thanks
Tfunz
