Samsung Galaxy S6 Wireless charger steal!
I'm not sure I'm following your question. The chargers are the same it's just the cases are different. I've purchased both the Galaxy S3 and the iPhone 4 versions.
Isn't there at least a color difference (black & white) between the two? I wondered, if the differences went beyond the cosmetic. But it seems not.
Received mine. It's a sharp looking product. I have an old iphone 4 I slapped the case on and charged. One irritant is when you pick up the phone the base lifts from the magnet.
Nice looking and the battery pack is a bonus, even in the case the capacity is low. It's a nice little deal to have in an emergency.
Not that I can see and I have both versions. Edit: I meant that I have both the white and black versions and only difference I can tell is color.
You can select between a black and a white version on the iPhone version page if you have a color preference. The white one is actually a dollar cheaper at the moment.
just went ahead and ordered a white one myself. Didn't even have to pay for it, used it with my discover points.
Got my 3rd one! The gs3 version!
Posted via the Android Central App on my Galaxy S5
So has anyone used charged their S6 with a case on? Wondering if it will still charge the phone.
I feel like I should apologize for this since everybody probably already owns more of these than they need....but they are $4 now....
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4333907
Great find on an insanely cheap wireless charger! Note, it does say this is an "add on item" so you can't just order this single item alone. Also, be aware the wall wart power plug is pretty long, and can cover up at least two outlets on a power strip.
That's not bad. Although I actually don't mind paying an extra 4 bucks for the portable charger to be included though. I'm so happy they put PMA charging in this phone too
Send me some type of prepaid envelope or box or something and I'll be happy to send you a few portable chargers for free. I don't plan on using mine.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4334186
Just got another one, for $4, I'll always find a use for it. FYI, the $4 price is an Add-On Price, so you really have to buy $25 or more in order to let you proceed to checkout, I had some things pending to purchase, so I bought everything together and it worked, just $4 for the wireless pad.
Thanks.
Thinking about picking up a couple of these. However, the only downside I can see is that it's a PMA charger, which has extremely low compatibility with most phones/devices, since most major phones seem ti use Qi. So if other devices that support wireless charging, chances are they won't be compatible.
True, but hey they are just 9.99 ☺ basically the price of your basic non-otterbox phone case. If 2yrs from now you upgrade and it no longer supports pma then at least your not loosing a big chunk of investment.
However I do hope Samsung keeps with universal wireless support and don't dump pma later like SD cards etc...
I think the fact that Starbucks stores use PMA will help keep it along longer. Without that, it would be dead shortly. But like you said, for this price, I don't care. It will work just fine for me for the 2 years or so I have this phone. Even if it was Qi, I bet 2 years from now there will be a faster version of Qi or something that would end up making you want to upgrade anyways.
Not sure if my pad is faulty or not, but it doesn't work when I put a case on my phone (Speck Candyshell case). However, my old Nexus 5 wireless charger does work with the case on so the case can technically work with wireless charging, but doesn't work with the duracell pad.
I must be doing something wrong, I'm trying everything with and without case and I can't seem to get my S4 to charge on here. Hopefully when my S6 comes I have no issues.
Does your S4 support wiress charging? If it does, does it support PMA wireless charging?
mattellis99
