samsung galaxy tab 2 ( 7.0 ) not charging / booting
Try holding all the buttons (volume up and down, and power) in at the same time for about ten seconds while the device is plugged into the charger.
This seems to reset the tablet and its charging circuit.
You may have to allow it to charge some more after that before it will power on.
The lithium ion batteries in these tablets aren't designed to be completely drained, and doing so can damage them.
Sent from my SPH-D710 using Tapatalk
Omg i literally created an account to thank you man 😭😭😭😭😭😭 God bless you
Hi, I've followed this thread and seen so far how many people you've helped as it were, but mine seems to be an exception for this solution even though I have the same problem. I've tried the above method and only the first time it got me smiling but couldn't pass the "samsung stage" (blinked thrice and went off). I hope trying this method repeatedly doesn't cause any malfunctions cos now the situation seems worse (plug charger_shows battery_*and goes off after few minutes*) as against (_ _*and remains on) PLEASE HELP, pls hlp :(
I wish l could give you better advice. Perhaps there is a problem with your charger or your cord; but likely the battery is damaged and needs to be replaced.
While it seems silly, I saw the post about cleaning the charger (this one was brand new from Samsung and still did not work) I wiped it down with a cloth carefully inside and out, then blew in to the charging port of the tablet like an NES cartridge, concentracting the stream of air, now the darn thing is charging just fine. I signed up just to thank you for that recommendation.
If I tried to reboot holding the volume up/down and on and off buttons down and my tablet did turn on for a second but it showed that the battery was not charging and quickly died again. Does this mean I need a new charger or do I need or can I replace the batteries? Please help.
Solution:- you must hold your tab's up ,down and power button for around 30 sec. or more
so that circuit will be reset. as your tab is completely discharged wait for it to get some charge for the basic operation till then dont use it. changing cable isn't solution for when your battery is completely drain. If your charger is broken then change it no problem.
I like to add another solution. Since I saw someone talking about diodes and input/output voltages. I had this exact same problem that the tablet just wouldn't start charging (went on and off) and I couldn't solve it with the button fixes or cleaning the connections. But I have a power bank which charges real quickly. So I tried the same thing while connecting it to the power bank and it suddenly worked. Just left it on there for a minute or two and then tried button fixes/turning it on while charging.
plssss help me i charged my samsung galaxy tab 2 7.0 and i saw the battery icon its showing x and not charging what should i do now pllsss help
Another working solution:
For people who still have problems, I have a solution that worked for me the first time i tried it (I am quoting Bill Griffiths who posted this on 16.05.2016 over at ifixit):
"My tab2 also refuses to charge if the battery gets too low. This is how I fix mine.
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
Bill"
Edit:
The procedure works too if you hold both volume buttons.
I accidentally held both and the power button, through this description.
carlgrims
