Samsung galaxy tab 7.7 stock recovery problem?
Hello,
to all of you.
I want to share some details with you, that I have found during the usage of tab, actually, the space of internal storage on tab is very low, so when I start my tab in safe mode and I uninstalled some heavy applications from the tab to free some space on the tab, on that time it started showing the free space but when it restarts again the uninstalled app come down and also the no same amount of free space is present that was before uninstalling the tab, same thing happens when I connect my tab with the computer during the safe although I got only very less time to do any task, but If I delete some program or some data from the tabs internal memory, on that time the memory shows free, but after restart the deleted data/app again comes and free space is again filled up.Actually, I am writing these details here because as suggested I dont want to factory reset/wipe data, so please I hope these things that I have observed help to understand the matter more clearly, I want to ask one more things, Is there some way by which I can repair the internal partitions of the android when it connects to the computer? or some other method? Hope to see some reply soon.Thank You.
Regards,
MOBILEGEEK6
When you delete the apps in Safe mode, does the tablet stay on longer?
From a Sprint Moto X using AC Forums app
Hello,
Sir,
Thank you for reply, the Tablet will restart in safe mode after 4 to 5 minutes, what ever I do in safe mode means either open message or check storage or uninstall some app.Hope this helps.
Actually, this matter has become a very strange and arduous for me to solve, because as you know I could not load recovery also loading of stock firmware give no result to me.
Regards,
MOBILEGEEK6
Hello,
Sir,
Regards,
MOBILEGEEK6
DO you have anything other files that are large, taking up space, like music for example?
I honestly think a reset is now your best option.
Hello,
Sir,
How are you? Yesterday I download a package of Stock rom from samsung-updates.com the package is stock ICS with the version number P6800DDLP5 although the mine tabs version number is P6800DDKL4 that is also on Honeycomb 3.2, I tried to load this package on the tab with odin firstly with ODIN V1.80, then with ODIN V3.70, both times I got a message like as undermentioned :
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> P6800DDLP5_P6800ODDLP5_P6800DDLP5_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/003> Added!!
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialzation..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> boot.bin
<ID:0/003> NAND Write Start!!
<ID:0/003> cache.img
<ID:0/003> factoryfs.img
<ID:0/003> hidden.img
<ID:0/003> modem.bin
<ID:0/003> param.lfs
<ID:0/003> recovery.img
<ID:0/003> Sbl.bin
<ID:0/003> zImage
<ID:0/003> RQT_CLOSE !!
<ID:0/003> RES OK !!
<ID:0/003> Removed!!
<ID:0/003> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
but when I restart a tab, the tab was in the same condition as before loading or upgrading this package, then I tried to load custom recovery of cwm with the odin I again got a message as undermentioned :
<ID:0/003> Added!!
but after restarting the tab the tab boots into the same stock recovery, now this matter has become very strange where everything goes fine until the tab restarts or tab loads the recovery, I've searched a lot on the internet but unable to understand what could be the problem even some experienced developers on some other websites has no answer to this problem, Sir, now, actually, I want to reset the tab and get rid of this problem, because its already many days since I use this tab in normal condition, but I am little bit afraid if even after reseting the tab this problem still wont go, then what would be my options then? I want to ask one more question from you actually, I am new to Android development, so I want to know If I load ANDROID SDK then Are there some programs or some utilities that can enable me to work with the internals of the tab? so that I can do something? Hope to see reply soon.Thank You again for all the help you provide to me.
Regards,
MOBILEGEEK6
Hello,
Sir,
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/003> Added!!
<ID:0/003> boot.bin
<ID:0/003> Sbl.bin
<ID:0/003> zImage
<ID:0/003> Added!!
Regards,
MOBILEGEEK6
As far as I am aware of, there is no ADB push command (essentially what you described) that can help with this.
I only now suggest a factory reset because all other options I can think of have been exhausted.
Hello,
Sir,
How are you? After all the options, I final decided to factory reset the device, I boot into custom recovery, there I choose the wipe data/factory reset option using Vol down key, after that I reboot the device my device still has same problem and to my surprise my all data is still present on the device, then I boot the device into safe mode, and I choose factory reset from settings menu, after that the device restarts, but same problem exists as well as my all data is still present.Now, Sir, What to do? Should I do something with odin in this case? Please reply soon.Thank You.
Regards,
MOBILEGEEK6
Hello,
Sir,
Regards,
MOBILEGEEK6
I really don't know what to suggest. As far as I know, everything that can be done has been done.
Hello,
Sir,
How are you?
Thank You very much for all the help that you provide to me, actually today I contacted the service center they told me that they will firstly try with the software, and if the result is not positive then it may be the hardware problem and needs to replace the whole motheboard, when I asked them with which software they work with my tablet they told to me that they work with odin, but when they work every thing that was on tablet removes and each bit of information will be rewrite afresh, Sir, I want to know Can I do it myself with odin I mean to say, How can I make sure that everything that previously written on the tablet will be rewritten and also please tell Is there any hardware way of resetting the tablet? Please reply soon.Thank You.
Regards,
MOBILEGEEK6
Hello,
Sir,
How are you?
Regards,
MOBILEGEEK6
Not that I am aware of, if it is a hardware problem, whatever hardware piece is faulty needs to be replaced. As for the software part, I am not sure if there is a way to check, aside from Settings>about device>firmware version or baseband version
Hi forum,
I've faced of the same problem :-( I can't even wipe data - everything come to primordial state... Does anybody found a solution?
carmilane
