samsung Kies Air
Yup, this worked if you've installed it before on another phone: Go to Play Store and select "My apps" from the Main Menu. There doesn't seem to be any replacement from Samsung yet.
this worked for me Thank you. Found it in play store apps my apps and reloaded it. The most current similar app to do this stuff but will not support my model is called Smart Switch.
Hi there,
Greetings from Brazil! For those of you still looking for the Kies Air app for Android, here's the link to the file:
(just remove the blank spaces)
http : // 1drv . ms / 1zsZhaL
Have fun and share! :)
Search for it on cnet. It will download via Google playstore and it works. I'm using a note 3 and s4 with 4.4.3 on both.
manjushree903
