samsung replenish emergency!!
No. The files needed from the SDK are inluded when you download LeafRom (adb.exe and some dll's). When you run cd, you would type something like this, "cd C:\Users\FirehaK\Documents\LeafRom 0.2" That being the location of my directory for LeafRom. If you just place the .bat file I mentioned above in that directory, you won't have to do this. You'd simply double click it and wait for it to tell you.
try to get the adb drivers to work..
they are kinda not workin
ok sorry i didnt spot this earlier.. if usb debugging is off then your going to get error device not found...
i have a possible solution for you.. you have a 50-50 shot right now (well actually tbh odds are a little bit better then that) of restoreing your phone or completly destroying it.. i was hoping to ask for someone.. but as your phone doesnt already boot would you be willing to test it out?
if it works then there is a way to recover back to stock (ew) and flash kernels
If you are hinting at Odin here, we still can't unless the Replenish has a way to get into download mode without adb. I haven't seen a key combination at boot to bring you there. "adb.exe reboot download" is the only way I know of. :(
And, new idea, Shabby! The update I sent you; What if it was placed under /mnt/sdcard/update.zip and ran from recovery? Our menu doesn't allow searching, it has to be right there. But maybe he/she could recover with it?
I'm sorry if I am not being clear enough hithereawesomeness. If you like, I could quickly record a video on using adb to see if your phone is in debugging mode at the recovery menu? And, what do you mean by the adb drivers are not working? Adb has no drivers, your phone has to have drivers installed on your machine to allow debug mode.
im liastenin shabby?
ok go for firehak
You will not be able to recover using the methods I used to recover on my own. Let's wait and see what Shabby has to say about his methods. I'm pretty interested as well. Sorry I can't help you any further, I'm brand new to Android myself.
Okay, I am interested to see if Shabbypenguin has a copy of the stock rom that is signed. If he does, then I may be able to recover by using the update.zip option on the stock recovery.
It's no problem. Still no luck yet. I just went through every single key combination while turning the phone on :(
so i went to sprint while here in newjersey which is my vacation.
they couldnt fix it either!
that surprised me so they referred me too a corporate place where they will try to fix and if not fixed then replace
so i guess shappypenguin can give me the info to a odin or that thing he mention
and also i noticed this..
a friend of mines who is good with flashin nd rootin said that when u try the flash rom by the recovery menu with pressin update.zip
it says its signature failed..any one think u can un-signature the device?
it seems the only way to me..
with leafrom 0.2
with leafrom 0.2
We had an official update file that needs placed in the root of your sd card and named "update.zip". It may help, but some of us are having trouble rooting afterwards. Would you like help on running the update file?
wont work, your official updates are patches applied to system files.. not actual files themselves. there is no way to recover his phone without odin.. we just need to crack teh button combo that boots into download mode
Just a suggestion. If his files are still there, I thought maybe it could patch them back to a working state. Still no luck on a button combination, but if you're good with electronics, you could buy/make a jig. I think that's what they're called, at least.
what a jig?
im sorry but im new to this.barely a month now
the guy said he tried to put the leafrom has signed by shabby but apparently it does not accept until a signature is given..which means?
still no hope?
i saw the tech guy press the volume button nd search button nd something else which turned into a linux codes
nothing. leaf rom isnt flashable by recovery, and we dont have the signature so recovery mode is useless to you.. what we need is download mode ;)
got a sprint source looking into it :) hopefully it will reveal some goodies
HandsomeZinck
