Samsung s6 edge plus or lg v10
aseve035
10
I'm in love with the Samsung edge plus. Its a beautiful phone and the display models I've tried are wonderful. I've spent a good part of an hour playing with a demo V10. Which would you choose and why. This would help me decide which I will buy. Price doesn't really effect me so what would be a deciding factor for yall
I don't think you can go wrong with either. I had the G4 before the S6E, and it was a great phone. The V10 seems to improve on that.
It really comes down to what you want. Do you need removable storage and battery? Do you prefer LG ui or Samsung Touchwiz?
LG isn't great at updates though, so there's that.
Honestly not to happy with either I they each have their pros and cons. The update thing does give me worries though
I currently have the S6 Edge Plus. I went to Verizon yesterday to check out the V10 & DT2. I'm on day 10 of my 14 day window. I spent about an hour in the store giving equal time to both. I concluded that neither device is an adequate replacement for my S6E+. To me the DT2 was too square and both devices give up a fair amount of screen space due to their on screen buttons. Also, neither device had that premium feel I had read in every blog.
I can certainly appreciate the specs and features the V10 & DT2 bring to the table. They certainly caught my attention. But in the end I think the S6E+ is the better device (for me). The only other phone I would consider is the Note 5.
Thank you
Regardless of the phone. I have the s6 edge + and love the Samsung pay. I use it everywhere.
I wouldn't worry. Samsung has been getting better with each Android release. I think it's starting to sink in with most oem's
Thank you
My pleasure.
Yeah. Sadly my bank isn't yet on board. Hoping for it very soon. Samsung Pay does appear to be the best of the bunch.
Now also the price. I thought the v10 was alto more expensive. But the 200 dollar difference kinda effects my mind (I'm cheap Lol) does the difference between the ticker screen and dual edge really make the two hundred dollar difference worth it
Depends on the carrier. I got the S6E+ from Verizon. They reduced the price $100 putting at the same price as the Note 5.
Guava121
