Screen shots of your battery life...
Still going strong. This is a whole nother phone after the reset.
Sent from my HTC One X using Android Central Forums
how much of an improvement did you see after performing the reset? i will be doing it this weekend, hopefully it helps.
Okay, what just happened? How did I get this much?
Basically I had medium use on it for the entire time, barring my classes and natural time of sleep. Even managed to watch a few flash movies on it. To be honest, it's scary.
(this is on an international One X)
Sent from my HTC One X using Tapatalk 2
If I disable some apps in the application settings will that improve battery life? Or lag?
Sent from my International HTC One X.
more than double. i went from getting about 12 hours off the charger with 2.5-3 hours screen on to 27 hours off charger with nearly 6 hours screen on.
But are my music, movies, downloaded and sideloaded apps, camera pics, other pics, downloaded stuff from the net, etc all erased?
Here is mine. Incredible battery performance better then any Android device I have used in the past and better then my iPhone 4s.
wow, what exactly happens when a factory reset is done? why such a drastic change? did you reload everything you had on it before you performed the reset?
there are a few things i haven't reloaded yet as i want to test them one at a time. i didn't sign into my htc hub account, i haven't added google currents or the flipboard apk back yet.
This thread drives me nuts. I'm lucky to get 10 hours before phone shuts down. Guess I will try the factory reset, though I'm not sure why it would help
all of you posting battery life, screen on time is HUGE!! please post that screen as well. I will post mine below.
OjDHPkJXGqO7ZK6sVnXeneZHIaBI3g98J0WZj_RD86anonal8SzLqWU11-txEtUGsIFT7JjUAKA
y3EVGd9AWfYvnGikYA4nyiEasE5Y-L1fI3FIiyxm2gABwvw8-0V5xCCnGITr_51gfHPLb_4Q8o8
battery life is great IMO, but there is no way ppl are getting over a day of life with 5-6 hours screen time...pics please :confused:
So far, so good.
yeah. ?there's no way. ?that's why it shows that i have 62% remaining after over 12 hours off charger and ?2.5 hours screen on time, right? ?i have already posted pictures. the only one i'm missing is the over 5 hours screen on time because that post was just a recap from the same charging cycle as my previous shots.
I get this from about 1 hour screen time and I think the standby time on this thing is really quite good. I would like to do a heavy use test now.
So far, so good.
thats great...but you are in an extremely small minority. those are the kind of numbers you would get with data turned off. must have a freak battery.
You were saying? You say I'm lying and want proof and when provided, something else must be happening. Right.
Reactions: Bizzle69
bro- relax, all I am saying is that nobody else is getting numbers like that...so obviously you have a freak battery or are doing something we aren't. simple right...if everybody was getting battery life like that it wouldn't be suspect at all...truth is, most people are in my boat and getting around 3+- hours of screen on time, which is phenomenal in its own right. stop taking offense, im not calling you a liar, but you are clearly a statistical outlier when it comes to battery life on the One X- basically, we all can't expect to get numbers like that even though you are.
I was getting 4+ hours before I was dipping below 20% battery left. I took it back due to the inconsistent battery life. I may go and get it again and see if the hard reset and other suggestions do the trick.
Flykxd133
