Screenshot does not work with anything
  • Start date Start date
A
AC Question
I'm using a non-rooted S6 edge. I also all the other threads in the forum. All the other askers were able to use at least one method. But it doesn't for me. I've tried
1. Palm swipe gesture
Checked whether it is enabled in settings. It is.
2.Tried holding both home and power buttons together for 1 second, 2 seconds. No capture.
3. Using third party apps. All of them require rooot access.
I was once able to capture the screen using palm swipe. The phone was new then. But now even palm swipe does not work. Is this some security option activated?
No 2 is the old classic that should work. Are you pressing them both at the same time? Practice a bit, it should work.
akutama1
