- Feb 6, 2017
- 99,023
- 15,709
- 113
download app from play store called radio switcher and change the radio band see if it helps
Edit :this method should work for you
Just did that. No change
Guess what? I did this and changed the band to "Class 10", restarted and the scrolling message went away to be replaced with the name of my carrier. And the carrier goes away after a few seconds. Only problem was, my phone couldn't receive calls.
Go into the dialer app and type the following:
*#*#72786#*#*
Phone should restart and re provision to the carrier.
You have to play which works best and hit the 3 dots in corner and pick USA if that's where u from
I will check back in because I'm at work and little busy
I tried them all. The only one that allowed me to place and receive calls was the "Automatic" band choice. The "United States" choice did not take away the scrolling message.
and select the one you have circled?
Yes, there area bunch of options there
Here are the options.
Try these 2
Those are the only 2 options that work. A couple others reduce my signal in half. The 2 options that work - no change - still scrolling message.
I don't know what I did, if anything, but it seems to only show up as a scrolling notification on the lock screen. Once unlocked, it goes away, but remains as a scrolling message at the bottom of the quick menu, and as a fixed message in the settings directly under "Mobile Network". I'm guessing with all the troubleshooting we've done, it's just a message I'm going to have to live with. Which I can do. I'll let Google and US Cellular know. I sure appreciate the effort.
Ok your welcome, if you have time play little bit
Automatic mode instead of usa
Then play with the other settings
One of those combos should do it
will do
Did you ever find a solution? I also just got the Pixel 3XL on US Cellular.We got it just stay in notifications panel so that's good , just need the right combination it should eliminate there also.
