SGBZ EVO Themes Q&A
hello
was the tutorial for the theme posted? did i miss it? or is it still work in progress?
thank you and sorry for the inconvenience
Its still in the works,im just a big slow poke. Really i just need to sit down and take the time todo it.
Quick question. Are some of the .png graphics animated, or are they all static and just swap one png for another when pressed?
Any estimated time frame on when these might work on deodexed roms?
I thinnk i got everything deodexed finally lastnight.I just have to wait to test(I don't have a evo).I have to check somethings out then ill be passing it on to get tested if everythings okay then ill get right on switching everything over.Hopefully soon.
Shoot me a PM if you don't already have an EVO lined up. I'm running a deodexed ROM right now BUT if i do this im going to request a Detroit Pistons theme be thrown into the queue :D
Wow had to re-read that thought you were offering to give me a evo:p
I got oneto test it on so hopefully everything went right.I think in time we can manage to get the Pistons up here;)
Re: SGBZ EVO Themes
Lol if I had an extra I'd certainly pass it your way. I'm famous (infamous?) amongst my friends for buying a new phone every couple of months and I usually just pass on the old ones to friends in need.
Miami theme
is there anychance you can make another miami theme with the clock transparent like the clear theme and make the top part of the clock orange and the bottem green? similar to the new jerseys.
I need to have it clear so i can see the wallpaper. it would all be cool to have the rosie transparent somewhat.
Also can someone please explain to me the difference between deodexed and the rom rvu? im running fresh rom now. so i would have to flash rvu then flash the miami in order to run properly?
in a odex rom like RvU there is a odex file that goes along with the apk. In a deodexed rom that odex file is converted in put inside the apk.Ill look into your request to add the theme.
GUESS WHAT!?!?!? I finally got some time to start converting our themes to DEODEX versions!
DEODEX VERSIONS ARE MARKED WITH THE LETTER "D"~!
ENJOY!
Hey beezy420, do you have a vanilla lock screen for the RvU ROM.?
You know i was actually going to do that the other day,but i forgot to check it out.Ill mess around with it later and see what can be done.I think the vanilla lock has to be fixed like it did for the hero.It displays wrong when just deleting the lockscreen.
thattoiletguy
