So where is the official Flash 10.2?
If everyone is so worried about the leaked version, back up all your data, install the beta version and if its corrupt, hard reset the device. I've been running it for over a week and haven't had one singe issue.
I have looked and can't find where to download the beta version everyone keeps talking about. Where do I find it for for my xoom?
Also, I just downloaded the 10.2 flash very for my droid X. Just don't see it in the market on my xoom
https://market.android.com/search?q=Adobe+Flash&c=apps
If you click on the link it brings up 10.1 but if you click INSTALL it brings up the installer for 10.2
Odd eh?
If you look when it's installing though it's 10.1
It does infact work though without any issues on the Xoom.
Also a side note... if you install it even though it says 10.1 while it's installing. When you go to the SETTINGS-->APPLICATIONS it says Adobe Flash Player 10.2
Interesting. If I go to the market on my laptop it shows up as 10.2 from Adobe. Just downloaded it and it works fine.
Find any adobe product. Click more by this author and it shows up on the zoom. It says 10.1 but when you install it it says 10.2
1. Search for Adobe Flash 10.2 in Market
2. Click on it and it will show Flash 10.1
3. Click install
Flash 10.2 (for Xoom) will be installed
3. Click install
i pushed it from my browser and it works flawlessly. its smaller too. i believe this might be what we were all waiting for!
Its out!
I just installed Flash 10.2 - smooth as silk!
Btw, its 4:09pm Mountain Standard time here.
TheGreatApe00
