So where is the official Flash 10.2?
For those not seeing Flash in the Market, go to Settings > Applications > All, find Market and choose Clear Data. Then go back to the Market and search for Adobe Flash, now you should see it.
Reactions: krazee-eyez killa
Thx Drew2u
Those instructions are perfect instructions on how to download this great update.
PlayOn?
Does anybody else use PlayOn? Works perfectly on my INC, but I get a blank screen on the Xoom. Otherwise, flash 10.2 works great - even with my web photography portfolio!
Does anyone know if it is possible to only enable flash when you click on an object, rather than having it automaticly run when you load a website? I can't seem to find the flash settings
I do. I found the screen was blank for a minute or so, but then the video would start. I tried it on Netflix and on my local Media files, same in both cases - just had to wait.
Thanks... will give it another spin and *try* to be patient this time :-) .
Edit: Yep works - but it is *VERY* slow to start, took almost 2.5 minutes to start a 30-second clip over 50Mbps WiFi... Pretty much unusable right now...
Sent from my Xoom using Tapatalk
Same, it loads but the screen never shows anything
That just sounds wrong. My X, Droid Pro, and XOOM load up Flash instantly.
Go to browser settings>Advanced>Enable Plug-Ins>On Demand
TheGreatApe00
