Soft brick? :( stuck in bootloop
ericm92
Hello,
I recently rooted for my first time, unlocked w/S-ON, but for some reason a lot of the ICS roms I have been running will glitch and bootloop. The most recent one began bootlooping before I could remove PH981.img so now I can't even access recovery to wipe my phone. I think I messed up and did not relock and install new firmware, instead I had tried to do it while still unlocked.
Please help! Phone will connect to computer but I don't get drive access. Thank you!
Yeah you need the right firmware. You can take the sd card out and that will get you out of that mess. Next I would pull one of the stock ics leaks connect the phone to the computer and run the leak as a ruu executable from your pc and not do the renaming thing. Once you do that, you will be on the stock ics firmware. From there you should have no issues with running the roms.
Rezound via Tapatalk 2
nabses
