Soft Key Background Mods....33 total
Re: Soft Key Background Mods....19 total
cool they both look great... i downloaded the cummins one last night but it didnt take for some reason will give it a try again today re read the directions for the zip themer :)
havent had the chance to try again hopefully here soon sometime today..
Re: Soft Key Background Mods....20 total
Will this work for the HTC Inspire?
If it does is there a plain red with no logo?
Amazing work i love them all. Thanks so much.. Was wondering if a San Francisco 49ers one be possible
Swyped From My G-Nex via Xparent Red Tapatalk 2
Can you please make one with the Stock 3 soft keys but switch out the home key with the nexus X?
You will only have 3 soft keys if that's what you choose in rom control (but I think that one will still show the home button with the nexus X...agree it'd be cooler with just the X)
Could you make one with the Nashville Predators logo "Gnash? Also, I'm on stock 4.1.1 rooted. Will this work? I tried a different Soft Key Mod, and it totally bricked my GNex. I usually just try it and see without asking, but I really don't feel like redoing muh phone. Thanks in advance!
Will this work on a 4.2.1 rom and the updated TWRP? I've been trying every way I can think of and I'm getting an error everyone I try to flash. I pretty much knew how to use it but read the manual just in case and I'm doing it right. Just keep getting errors when flashing.
Sorry guys...I have been neglecting this thread.
I will start updating your requests and i have a few others i want to make, so keep an eye out over the next couple of days.
I have not been able to make these work on any rom with a theme chooser theme installed.
I have tried a bunch and installed these before and after applying the theme to no avail.
but if you are using the stock theme they work fine (i am currently on AOKP 4.2.1 nightly)
screen shot
Another note:
If you use a rom that can change the glow color, it will change the entire background to that color.
no multicolored backgrounds on AOKP. i will test more ROMS tonight
Sorry, these are just the background images not the soft keys.
make sure you update Edify
open zip Themer > settings > update Edify > select flashable file browse> locate on your device the theme you are currently using > hit configure > wait for the success popup
then build it
and as always, make a nandroid just in case.
Can you make one with the Ohio State Block "O"? I am a HUGE Buckeye fan and this would make me the envy of all my friends. Thanks for the great work!!!
OP Updated
Added 8 more soft key backgrounds and should be caught up on all requests.
I will keep making them as long as you guys keep using them.
P.S.
It hurt to make the buckeye background....yuck. Go blue :p
Enjoy
Hi, can you make a background with the Yankes "NY" logo, or the script logo? Thanks
Re: Soft Key Background Mods....29 total
OP Updated
P.S.
Enjoy
Looks great! Thanks
How about the Marine Corps. Globe and Anchor?
Also, will this work on the Sprint Gnex? I couldn't imagine there being an issue but it doesn't hurt to ask.
yes this should work just fine on a sprint GNEX
I will work on it as soon as i get a chance, probably later tonight
Tigerchota
