[SOLUTION] For those who are having problems with their phones after updating to Jelly Bean
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Just do a factory reset
You contacts and calendars will be backed up to Google
Your apps should automatically re-download to your phone
You phone should be running the way it supposed to be
...just letting people know since it seems like most didn't know it
bobbyp5
51
I had the problem where I had to download the package and flash it through odin. My baseband was jellybean but it still said I was on ICS. Strange thing but I'm up and running. Just wanted to add that in there.
anon(94115)
Banned
Nov 29, 2010
5,697
511
you will lose the data for your apps (games progress, most passwords and the like) but it is the only way to get a nice clean upgrade
I always
factory reset
update
factory reset
set the phone back up
your internal memory and sdcard should be fine
Archienj7
102
4
I always
factory reset
update
factory reset
Reset your battery as well, take out 40 minutes, run completely dead, charge it while totally off, done. It fixed the battery plummet issue for me and a few others.
