[SOLVED] How do I disable zen mode notifications from my phone.
  • Start date Start date
Re: How do I disable/uninstall zen mode from my phone.
This arrow in my screenshot of your picture , can you expand it and do more with it?Screenshot_20190824-132219.jpeg
Do you want me to move this thread to the 6T forum for better visibility?
I'm not the OP but if you think it would help us find a way to stop these notifications I don't care where you move it to. In the oneplus community forum there's posts and contents from people with phones from the 6 up through the 7 pro with no option to turn them off.
Don't worry about that. I already moved the thread and we'll see if we can get more feedback from other owners.
Do you have a link for the OP forum? It could be great to have it here for future reference.
I will try to the next time I get a notification
There's a way to go there even without the notification, go to settings - apps & notifications - see all xxx apps - three dots top right - show system - scroll all the way down and select Zen mode.
Yes, that's one of the screen shots that I've posted. What should I do there? It will not let me toggle it on and off
Yes, it seems those settings are different on the 6 models
Oh wow! Thanks.
Here's another, it's from oneplus themselves and is mostly full of comments from people that want it. But there are a few of us that think it should be our choice that can't disable it in the comments here
I don't have the notification on my phone right now. That picture is from Thursday. I will try to open that spot the next time it pops up
Ok no problem, I will check on this further with my 1+6 later tonight
Just in case I disabled everything for Zen mode notifications :)Screenshot_20190824-144737.jpeg
I found out that it's included under OPskin so you can't restrict background access. :(
Thank you both Javier and Mustang very much for trying to help.
liquidsnake757
