[SOLVED] How do I disable zen mode notifications from my phone.
  • Start date Start date
Re: How do I disable/uninstall zen mode from my phone.
And Mustang has the 7 Pro and the 6T.
The 7? Are you in America? Maybe it's something we're not offered here
I live in Brazil but I bought it on my last trip to Europe, I'm from Madrid. I prefer the non Pro model for a few reasons.
IIRC... the OnePlus 7 series on stock OxygenOS and the OnePlus 6 series on the latest Open Beta release, are running the latest version of ZenMode, v1.3.0, see screenshot of my 6T on OB16. This has more options than the Zen Mode, v1.2.0, on the latest stock, stable OxygenOS releases for the OnePlus 6/6T.
You could download Zen Mode v1.3.0 from apkmirror and sideload it.
We weren't offered the 7 here either, only the 7 pro. Never will I ever buy a phone with curved edges on the screen
Is the a why to turn it off completly?
Is there a way to turn it off completly
I am rooted and just use Titanium Backup to freeze Zen Mode.
If oneplus doesn't give us a way to turn this off very soon I'm either going to learn how to root this phone or use it for stress relief with a hammer
These are the options on the new Zen Mode v1.0.3, which allows multiple durations of Zen Mode and the turning off of notifications... among other things. This version should be included in the next stable OxygenOS update for the 6/6T series.
These are the options on version 1.1.0, the one I have.Screenshot_20190824-161955.jpeg
I certainly hope that we can. It should've been there from the beginning
Which Zen mode app version do you have?
Isn't mine newer than yours?
You could try this. Make sure you have the Zen mode tile in the quick settings panel, if not tap the edit/pencil icon and drag it there. Tap the tile, go through the three explaining screens and tap next, tap the clog/settings icon top right and see which options you get.
😁😁😁 You are my hero if this works!!!
I almost missed touching the gear cog on the third setup screen and would've enabled zen mode by accident.
That's crazy, you have to turn it on before you can turn it's notifications off
hincapie
