Sprint's LG G2: Official KitKat info - Candy coated goodness.
If anyone is still reading this forum that's having problems with calls,I went to the sprint store and they fixed the problem.Click on settings,then more,then mobile networks,then network mode,then click CDMA or if you have 4G/LTE in your area,click LTE/CDMA. Just make sure Global is not clicked.
I've been using Global since day 1 with mine and my wife's G2s with no issues.
Sent from my LG-LS980 using AC Forums mobile app
This may sound silly but what is KitKat? Is it automatic or what? I'm using an LG G2
It is the name for the software version of Android. They follow a confection name in alphabetical order. KitKat, is the most up to date version. Updates are usually over the air (OTA), and depending on your carrier, may already be rolling out.
Sent from my HTC One_M8 using AC Forums mobile app
From what the sprint guy said,global is used when you go overseas and the radio is constantly searching. When I upgraded to kitkat,my phone no longer received calls but everything else worked as it did before. Since I have no 4g/lte in my area,only cdma was checked,the phone has worked as it did before the update to kitkat.
Tfunz
