Yelp I'm have all that checked and the right file:'( does it has something todo with drivers I have those but I dont know what to do now my phone want even turn on only thing I can do it put it in downloadMake sure that you are in download mode, and odin is seeing your phone. Use the pda button to find the .tar file and only have reboot checked.
Well, I'm not sure what the deal is with the froyo android keyboard is, but it just didn't let me pound out the messages like it did when I was on eclair. Luckily, I found the gingerbread keyboard which XDA has created that you don't even need to be rooted to use. Renamed Gingerbread Keyboard - updated 2010-12-28 - xda-developers I don't have any problem with rooting, but I really don't have much need for it so I'm waiting until I've absolutely got to have it. I was about to try TER but then official froyo was announced so I wait. I think once we've got an EXT4 rom based on EB13 I may go custom roms as I think that will be the only path to Gingerbread with this phone.Ok, I updated my Epic by putting update.zip on the sd card. Everything went great, no issues there. However is anyone else noticing that the android keyboard no longer has any "smarts". It just types the letters I press and the autocorrect is essentially useless now! What gives? Did I do something wrong?
I would double check that you have the correct driver. Also, try getting rid of the .md5 so that the file ends in .tar
I did all the steps and booted into stock recovery and get this message:
E:failed to verify whole-file signature
E:signature verification failed
Installation aborted.
What do I do now?
The download is saying 91.1 MB from Samsungs website.I am guessing the whole windows installer. Make sure when you download it, it is around 200 mb. Then get the .tar file and try again. If not maybe odin back to eclair and try from there.
Well it looks like I have to make a visit too then cause nothing is working for me :'( What did you tell the sprint rep ?Windows method worked for me from the leaked froyo, but screwed up my sister's phone (though sprint store was able to get it working again)
Thanks a million for sharing. With your post i was able to dl the mac version zip, move it to my sd card and apply the update.zip file, with no pc!!! Thanks again for your post!!!
No waiting for my ota......woot!
