Sprint's Samsung Epic 4g Official Froyo EB13
How did your update to EB13 go?
  • Total voters
Status
Not open for further replies.
Hey Paul if I just want to wait for the EC05 OTA should I flash my Epic back to Eclair using Odin or leave it on the Froyo EB13 I got through the update.zip? I have not rooted yet by the way.
You could do that, I would wait into the weekend I am sure this question will be raised about those who officially updated to EB13 and how they go about upgrading to EC05.
I would bet its safe to say you will recieve the OTA update and also have the option of update.zip or the other methods as we had with EB13.
paul - does this really mean we will have to flash an updated ace rom?
aside from sprint id, what is different?
Not sure.. Probably not much aside from Sprint ID. As far as the custom ROMs go, the change over for us devs should be pretty easy... Sprint ID will be the first thing every dev will look into ripping out of this update.
Maybe we will get a solid blue tooth out of this version for those who had so many issues..
took them a month to fix this after pushing back the initial release for what, three months?
pathetic
i would laugh if after two days next week, it gets pulled again because of errors.
because i am rooted with stock apps removed, will i even get the notification?
Same for me. Since the EB13 update, I have rooted my phone using the process described here. What steps will I need to take to get the new update? I have indeed removed apps (Sprint stuff). Will this mean I need to restore my phone to stock and then apply the update file or will the update simply overwrite what is on there now?
No you will not recieve the update with the Sprint apps removed.
Best thing to do is a backup in Titanium or MyBackUp Root and then Odin back to Stock EB13 and then once you update to the new EC05 and root again you can restore your backups.
I figured that might be the answer, but I was sure hoping I wouldn't have to do all that (I'm pretty freaking lazy, took me like 5 months to even root the thing)
I'll look here for next week for all the info and new procedures.
will mybackup backup my app data like angry birds?
cant lose all of those stars!!!
It should under APPS for your backup. I would also for extra protection download and install Titanium and do a full backup of Angry Birds on there as a secondary.
Reactions: robomav
Question;
I am completely stock EB13 Odexed (from samsungs update.zip) and rooted with oneclick root cwm 2.5.5 (when running it says cwm 2.5.1.0) with all the bug fixs applied. I am running just perfect!
With that being said - Technically if you removed some Sprint bloatware you won't receive the Sprint ID OTA update.
If that is correct could I just remove for example the nascar app "nascar09-prod-release.apk" in the system/app directory via root explorer and that would stop me from getting the Sprint ID OTA.
OR
Maybe there is a hook I need in the update to keep the Sprint network connected?
is it true that the 2.2 ota will resume 3/21~3/25???
I read somewhere that the update will be released Monday...has anybody else heard/read about this???
Ok I don't feel like scrolling thru all 81 pages.. I have EB13 manual update. How will I get EC05 tomorrow?
If your still stock, don't worry you will receive the update.
If your rooted, as long as you haven't installed any custom ROMS, kernels or removed Sprint/Sammy bloatware you will receive the update.
All else fails you will still have the manual updates to fall back on as before.
There are already custom ROMs based on EC05.
I was just wondering if I have launcher pro running will I get the update, or should I go back to touchwiz?
Status
francomattia
