Stuff taking forever to load...
Can confirm that the problem (for me at least)was ipv6. Swapped out for a new router...ran the test again. No fails this time. Everything loads as fast as it should.
That's great. I'm using LTE only for now. Good thing I have unlimited data.
Did you try my last suggestion, about doing the forget the wifi connection, wipe cache data and connect again?
Go into your router settings and disable ipv6. Everything will work fine with ipv4 (only) for a small home network.
Sent from my SM-N920T using Tapatalk
THANK YOU! This is exactly what I needed. This fixed the problem. Now my Note 5 is blazing fast on my Wi-Fi!
Some (my)routers don't let you disable ipv6.
So replaced it since it was a lease.
All is right with the world again .
They should. No router should be ipv6 only for a home network. It really isn't needed.
Cheezy313Bby
