Does not work in VC.
Tis been a long day for me, myself and I. *passes out*
Roadmap for tomorrow (it's 9:11pm for me as of now):
1) Sprint ID remove/restore
2) Launcher switching
3) MAYBE kernel flashing
Drellisdee's custom recovery is the OG custom recovery.
Did you attempt to flash xionia clockwork recovery while in recovery mode? Cause that won't work at all.
For an out of the box refurb with V9, you can just Force Flash VC using the instructions in the reference section.SFHUB,
Are you saying that if one has OTA VC then they can KP500 with Zefie's VC cab? we dont have to go V9 then back to VC?
No, look what I did is that I unlocked it like it said, pressed allow really quick when it appeared, and it went into android recovery. I pressed reboot and let my phone load. In about 5 minutes later I wanted to flash thunderom but when I went into recovery, it was android recovery and not xionia clockwork. What did I do wrong since I followed the instructions step-by-step on screen?
EDIT: wait sorry, I just read the lg optimus control center post and I noticed it said "install kernels" and stuff. Does that mean that the custom recovery is installed in my phone but I haven't put/flashed it there yet? If so how do I do that?
Go through the custom recovery installation in the Control Center again. This time choose drellisdee's custom recovery. And no, the Control Center is designed to flash the recovery image for you.
Huh, I could have sworn I included 1.2 with the Control Center. Weird. That will be included in the next update for sure. If you want you can download 1.2, rename it to drellisdee.img and overwrite the one in the "customrecovery" folder.
So, I:
1. Had USB Debug enabled
2. Ran the tool, and unrooted my manual root I had done after the LG Updater tool update, and rerooted using the tool
3. went through the process for installing the Xionia custom recovery, reaching the "successful" message
The phone reboots, but I still don't see the new recovery, just the same old stock recovery......
What am I not doing correctly?
Did you verify that you were ACTUALLY rooted? Sometimes it doesn't work, most times it does. Reboot recovery and run the root tool again.
EDIT: I need to ask this, because it is important. Did you apply the V8_to_V9 update.zip and get the expected error message?
