Sync Notification Sound Levels
mush10
195
Does anyone know of a way to make sure all notifications stay in sync sound and vibrate wise? I have always just used the volume keys but with the settings icon allowing you to change different volumes for different notifications it is causing problems.
I think the ability to change individual notifications is a solid option, I would also like a way to change them in sync. There are time where I think I have silenced the phone and a certain notification still has sound. I guess a widget could work but I usually like to only use the keys.
Thanks in advance.
Posted via Galaxy S6
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Thanks in advance.
Download this app called AudioManager Pro...its what I use and it works perfectly
You can set up icons to turn every sound off at once, or on, or turn everything off except vibrate. You can also set up custom presets
mush10
195
Thanks for the idea. I will check out the app. I wish I could just rely on the volume buttons but app it is I guess.
vergoña69
