T-Mobile Note 3: Android 4.4.2 (KitKat) update problems and issues thread
Re: Android 4.4.2 (KitKat) update problems and issues thread
You're both using different types of Screen Lock methods. One is swipe is secured with a Auto-Lock. FYI I also have the same options as the user with the Auto-Lock as I have PIN enabled as my security method. If you change the Screen Lock method it should change accordingly.
Oh ok sorry. I have no idea what it looked like before, I've almost always had swype as the screen lock
Sent from my SM-N900T using Tapatalk
Does anyone who has updated notice the click sound when unlocking the phone is gone? Is this a bug? I use a PIN and button savior if that's relevant. It worked with sound prior to Kit Kat.
Hello,
Just purchased my self an Sm-N9005 from Jordan Sim free European model. A couple of my colleges are running Kit-Kat and the same phones however I have not received the update as yet. I have checked this by checking for updates.
My Phone details are as follows:
Model - SM-N9005
Android Version - 4.3 Jelly Bean
Baseband - N9005XXUDMJ7
Build Number - JSS15J.N9005XXUDMK2
can anyone advise me as I'm new to Andriod.
Wrong thread man, this is for the T-Mobile note 3 look under international note 3
stuff that changed under 4.4.2 kitkat
* clear the apps cache after update
Tap to pay not working/not working as intended
http://forums.androidcentral.com/t-...pdate-problems-issues-thread.html#post3493586
response (works now): http://forums.androidcentral.com/t-...-note-3/368139-google-wallet.html#post3496976
Not able to write to sd card
* move apps to internal storage before updating OS
http://forums.androidcentral.com/t-...pdate-problems-issues-thread.html#post3493805
http://forums.androidcentral.com/t-...te-if-you-value-your-sd-card.html#post3493836
http://forums.androidcentral.com/t-...te-if-you-value-your-sd-card.html#post3496566
response (it's a security "feature", needs root to undo): http://forums.androidcentral.com/t-...te-if-you-value-your-sd-card.html#post3493917
Not charging with an aftermarket cable
http://forums.androidcentral.com/t-...pdate-problems-issues-thread.html#post3494482
Notification panel doesn't separate active & passive notifications
http://forums.androidcentral.com/t-...pdate-problems-issues-thread.html#post3494494
Black and white notification icons
http://forums.androidcentral.com/t-...pdate-problems-issues-thread.html#post3494615
Losing root
http://forums.androidcentral.com/t-...ate-problems-issues-thread-2.html#post3495195
resolution: http://forums.androidcentral.com/t-...ate-problems-issues-thread-2.html#post3495469
Can only have the watercolor or ripple effects on lockscreen if you use stock wallpapers
http://forums.androidcentral.com/t-...ate-problems-issues-thread-2.html#post3495307
Voice controls not working for answering or rejecting incoming calls
http://forums.androidcentral.com/t-...ate-problems-issues-thread-2.html#post3496308
response (will not work if vibration is on): http://forums.androidcentral.com/t-...ming-call-answer-reject-inop.html#post3496963
Google wallet doesn't work
http://forums.androidcentral.com/t-...-note-3/368139-google-wallet.html#post3494310
response (never worked on TMobile, requires root to enable): http://forums.androidcentral.com/t-...-note-3/368139-google-wallet.html#post3494365
Kitkat forces you to use the stock messaging app
http://forums.androidcentral.com/t-...-message-issues-after-update.html#post3496109
Reboots after EU 4.4.2 update
http://forums.androidcentral.com/samsung-galaxy-note-3/367540-note-3-4-4-2-reboot.html#post3489990
Third party accessories not working after update
Update: Samsung Galaxy Note 3 KitKat update disables third-party accessories | Android and Me
response (no link between update and problems): Samsung: no link between Note 3 KitKat update and nonfunctional third-party accessories | Android Central
another response (it's broke, will be fixed with OTA update later): Samsung Admits Galaxy Note 3 KitKat Update Disabled Third-Party Accessories, Will Deliver OTA To Fix The 'Bug'
im having longer than usual app update times
Battery life is awful now...
Sent from my SM-N900T using AC Forums mobile app
I'm having the same issue. I haven't really read anything else about it so I was going to take my phone in. Anyone have any suggestions on the battery issue after the download?
Okay, since the update & subsequent battery drain, I noticed it was running a little warm also, figured out it was the gps. Turned it off from the swipe down screen, at first, no difference. Went into settings & saw gps was still in the on position, turned it off, & now my phone is a normal temperature & Battery life seems normal again. I don't know why this changed after the update but hope it's fixed soon as I usually have location services turned on all the time. Hope this helps someone! Also, I'm going to turn it back on to see if it still drains the battery & get back with an update
Make sure the update didn't turn anything on that you didn't have on before and also re-enable apps that you had disabled. You'll have to go through everything in the app manager. Turning off Google now and G+ returned me to stellar battery life. Over 6hrs screen on time over a 16hr day.
Also before the update I had lte disabled since it was showing a crappy lte signal. Since the update and increase in lte signal strength I enabled lte. You might try that if you're in an lte area.
Sent from my T-Mobile Note 3
Just noticed in app manager that "software update" is running, never showed up running before & I've already updated... Could I shut that down without screwing up the phone?
Anyone having wifi calling problems after the update? I've had a few instances where the phone would fail to make an outgoing call when on wifi. The text messages are also slow coming in. I receive a bulk (several) texts at the same time that more than likely were not miraculously sent at the same time.
I have an issue recording video in 4k.. Stops after 5 minutes even though I have about 30gigs to record to..
Oh...tmobile knows. .. my phone crashed this morning after trying to uninstall an app, had to do a factory reset. I asked if I should reinstall KitKat os (although it installed with reset) , Rep told me definitely not,too many people with too many issues & not minor ones. .. told me to wait till they update this version in a couple months. Luckily I'm not having any problems since reset...Time will tell. ..
How does one ensure that you have to opt in to get the update? I don't want a ninja update, without my explicit agreement.
Sent from my SM-P600 using AC Forums mobile app
Why in the hell is Android eating up nearly half my battery life with kit Kat?? What have you done to my new Note 3 Google? It's 3 days old!
slackingfred
