Taskbar, really samsung
It will come in a OneUI 4.1.1 update… most likely next month. Because OneUI 5.0 is on it’s way in a few months.
Hopefully, i had 2nd August update thought bring some features but looking forward to next months update and when beta comes for the fold³ im currently in beta for s22u but that's going back on tade in for Flip⁴
I love Nova but end of day when rolling with Z Fold I used stock and called it a day...
Yeah, I’m really anxious to see what Samsung will do for OneUI 5.0 on Galaxy Fold. I was disappointed that Samsung opted to not add 2 column layout for the Notification Center with OneUI 4.1.1 because it’s on Android 12L. I’m hoping they bring that to OneUI 5.0.
Hey! You’re here! And I agree with you completely… I been a Nova user for years, decided it was time to see what Samsung offered for OneUI.
Learned about Good Lock… been a stock user ever since.
I hope they bring back grid size layout to notification panel , but in beta 13 5.0 they reduced the notification panel first pull from 5 row to 4 icons across
Haha yeah man ..all over the place ...Fold only phone I think stock launcher serves well ...I like the task bar thing and hopefully they keep improving
Well I've been using the stock launcher and it's been working, but.... Samsung needs to stop forcing crap on people. They have this thing called finder. I don't want it and you can't disable it. Why not give the user the option to turn that off? Why is it on the fold 4 and not the tab S8+? This is a feature, is it really necessary to force it and not give option to turn it off.
If there's a way to turn it off I would appreciate it. Google search I did said it's not possible without using something like alliance shield. I'm little concerned about permissions required for that app.
I use alliance shield x and package disabler pro
Finder is how you search the phone for stuff from the app drawer. With the home up module with goodlock you can set this to where a swipe down on the homescreen will open finder.
I am pretty sure this was one of the most requested features to be brought over from ios to android. Its literally one of the most useful features on a device.
Can do pretty much same in settings menu at top search just type it in
Finder searches your settings with out needing to open settings. Spotlight is my favorite ios feature and I was happy to learn about goodlock implementing it via the home screen.
If it works for you thats fine by me , i have it disable no use for me .
Does Finder actually consume any resources when not used? Why the need to disable?
For me it's when I open app drawer I just want to swipe up or down to go back to home. It's annoying I forget which one is that finder thing. I don't use finder or want it so why not let people like me disable it.
Hmm, maybe I'm thinking something else. When I swipe and or down in the app drawer, I go straight home. Isn't Finder only activated when you use the search bar on the top of the app drawer? Anyway, was just curious if I was missing something.
Not on my phone. In app drawer if I swipe up it goes to home, if I swipe down it goes to finder. When in finder I have to wipe up twice to get back to app page then swipe up to gonto home. Very annoying when it's something I don't use.
djdjjkzzz
