Text notifications cut short?
what fixed it for me, don't recall where i heard it but i did not come up with it.
here it is, messaging, settings, delete old messages. i unchecked that and it has been working fine for days now. My wife and i both have spring s3 phones, hers was fixed also.
now the message delete is very nice on this phone. i use to long hold, then delete. on this, with the messages showing, left button, delete messages. this gives check boxes next to the messages to batch delete.
hope this helps,
Joel
does this problem only happen with the default sms app? theres some much nicer ones on the market
I have the same issue and reported it to Samsung via their FB app.
[edit]
I deleted my old SMS and it looks like that cleared the problem. Thanks!
[/edit]
I deleted all my txts and it worked till I had about 6 txts before it played up again. Just unticked the delete old msg box and will see what happens.
Maybe I should refuse to accept this unreliability and change to scapple?
NNOOOOO! :)
Yes, when I get a text as well, only half my notification tone plays as though it was interupted 1/2 way though playing it.
Bugs the hell out of me.
Posted from my Sprint White GS3 via Tapatalk
I just turn my sounds off! Maybe they can patch this?
Sent From My Samsung Galaxy SIII
If people don't report it they can't fix it.....
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
It fixed the truncation but notifications are still stuttery.
I have been talking with @samsungsupport on twitter. I have also directed them to this thread. They seem very eager to address the problem.
True the problem is only a small annoyance but still.
I'm glad to see their support staff is so responsive.
This issue drove me nuts, however I have the solution. In order for the notification sound to play the entire tone, you must delete old text messages. It makes no sense, but I promise your problem will be solved.
Bingo, worked for me. I just unchecked the automatic delete option.
@ funkylogik I use the whistle text alert tone. It plays about half before it stops.
I have the same whistle for texts and get the notification cut short...i just thought it was the service in my area but looks like many others have same problem
I unchecked auto delete and installed Nova launcher at around the same time, now it either plays the notification completely or not at all, unless I delete all my messages which is a total pain in the arse.
Using Go sms for now
Adekanmbi
