The have you gotten Android Lollipop 5.0 thread!
this method works but it might screw up your device's Google Cloud Messaging (GCM) requiring a Hard Reset/Factory Fresh Wipe in order to fix GCM and Push Services (Gmail etc.). i like to do a hard reset after every Letter OS Update anyway. it worked for me on the second try. if you try it report back. here you go - good luck -
Pradaman Shorey
Shared publicly - 2:31 PM
#Nexus5
How to force Lollipop Update on your Nexus Device:
1. Go to Settings > Apps > All > Google play services > manage space >
clear data.
2. Go to Google Services framework > clear data > force stop.
3. Go to Settings > About phone > system updates (it should say last
checked in 1969)
4. Click on 'Check Now' & keep refreshing and it should push the
update to your phone if it doesn't work the first time keep trying.
It worked for me in the first go (Nexus 5)!!
Good Luck...
#lollipopupdate #nexus #update #nexus5 #lollipop
#google
https://plus.google.com/+PradamanShorey/posts/RhmXWhoE6Be
Force Android OS OTA Update
GermanAndroid2403
