The LG G2 has themes?
Re: lg g2 has themes??????
Use the link Stardate Tab 10.1 posted above and go to the first page of the thread. The best ones I've found over there were under the Dropbox link, "good themes” folder. Crystal 2 final, mui, and Vanilla theme are a couple of good ones. KitKat is within the thread as well.
Sent from my LG G2 via Android Central App
Ah, those are different themes. I thought I already had all of the themes from XDA. Cool, I guess I'll go get those then.
If you're looking for the Smart World app just go to www.lgworld.com and click the download link that shows up on the screen. You will need to check the box for Unknown Sources in the security settings to install the app.
And remember themes are only for the stock launcher. If your running nova or apex or something like that themes don't work.
Sent from Bad Azz VZW LG G2 Cyan Tapatalk
One thing to remember is if you get a theme that doesn't have the transparent bars and you want them you can switch to a stock wallpaper.
I think LG should open up their themes more myself. This is the first time I've used a stock launcher in a very long time. Would like some simple things enabled like changing folder icons or removing app labels but other than that I'm pretty much happy with this phone stock plus a theme, running the e kit kat one now.
I'm running the Kit Kat one as well. I like it a lot.
thats what i want.
i want themes for the stock launcher. i love the stock launcher.
Why on Earth did AT&T remove the ability to change themes? That's so sad. And such a silly thing to remove. Doesn't make sense.
I'm sure if you are rooted there is a solution. Flashing a ZIP or having someone add it to their ROM.
Question:
When you apply a theme does it reset all of your Icons/Apps and Widgets on your homescreens?
TIA
I have the G2 on Verizon, and when i goto that website i get the msg that it's only for LG phones and my model is not supported. And the other day i came across a post where someone was saying you had to have that Apptoid store/app downloaded. That doesn't sound right to me but what do i know. All i know is LG's smart world doesn't seem very smart too me lol. I'm running Nova anyways so it won't do much for me anyways.
I'm on EE in the UK and i have themes facility. I haven't seen any decent ones in the market though, mainly because even the most complete only have about 800 icons
LG G2 has the best native theme management compare to other android device.
Sent from my LG-D802 using AC Forums mobile app
john_russell
