The update to Sense 6.0 and other changes imminent
Settings, Battery Manager, Extreme Power savings mode (footnote 1), touch button next to 20% and be sure to select "Automatically turn on extreme power savings mode at level I specify...."
Footnote 1. Do not turn the slider next to Extreme Power Savings Mode to ON from this menu item, or the mode will be ON all the time.
Thanks! The bolded is what I kept doing LOL.
Man, I really messed up. I was trying to fix Blinkfeed and deleted the data and cleared the cache and that deleted all of my phone icons and widgets from my screens and set them back to the defaults. :(
I am going back and adding stuff, but some things look different. I use to have a calendar widget which was opaque 1x4 and you could scroll through your meetings. The only 1x4 I find now is white and only shows your next appointment.
Anybody know what I can do to change opacity on widgets?
Get more calendar widgets that work with multiple calendars?
EDIT: OK I figured out I had installed simple calendar widget, which shows as installed, but those widgets don't show up in my widget options :(
It seems to me that I Power Amp was also see through widget, but I can't figure out how to change that either, as well as I though folder icons where also opaque, but now they show up as a dark grey box around the icons :(
how do we turn blinkfeed off completely?
Long press on the home screen. Select manage home screen panels. Swipe over to BlinkFeed home screen. Select remove.
Sent from my HTC One using AC Forums mobile app
I had terrible battery life today for the first full day, but no panic. I know it takes a few battery cycles after a reset/erase, and new OS loaded.
Hey
did u guys know that you can stream youtube from your phone to your roku or other tv device?
So cool, just found that out by playing around with the you tube app
it also changed my alarm sound. it changed it to something much softer and i overslept. thankfully i have my ipad alarm set also.
Hey everyone, I still am on the Sense 5.5 and I want to know different peoples verdict on Sense 6.0! I am still hesitant to update because of all the changes (different set of ringtones/sounds, battery life, new greenish theme, camera, etc)
In my opinion, the update is worth it. The battery life should be better after a few days. I use all my own sounds and ringtone anyways.
how many colored themes are there in the new sense 6 ?i can only find orange,purple or green..
there are only 4 wallpapers so how many colors have u guys found?
and what are the different colored squares for on each wallpaper frame?
and i dont see any silver or grey options
Has anyone using exchange server having problems syncing contacts? I lost all contacts after update and now I keep getting error when trying to sync. Mail,etc syncs fine.
I am a Sprint customer, but am having the exact same issue with exchange syncing contacts (mail, calendar sync fine). I also have a Google account on my phone, and the contact sync fine with that account.
In the AT&T thread of the HTC One forum, joew3 gave the following suggestion (it worked for me, too):
"I had a similar problem. Try removing your Exchange ActiveSync account from your phone and reinstalling it. It worked for me. I hope this helps!"
RichardDixon
