[THEME] Customt dialers for 2.2, 2.3.3, Reborn & Swype Metamorphs
just tried this one, this is EXACTLY what i ment and was looking for great job man!! on this version i still see green tho on the tabs above the dialer but i dont mind 1 bit, its flawless
Yes this Dialer Theme is Awesome! The angry android is sweet! Thanks for making this! It looks great w/ReBornROM and I'm using the Blux AS theme for GO LauncherEX and it looks great!
Would be cool if the tabs at the top were grey and not green like in the first pics of this dialer... :D
Reactions: omarnova
does look sweet but all the credit goes to "thekraven" hes the one that made this happen, i simply just gave him some ideas. if u got any ideas or color schemes, post them.
Is anybody else getting force close error when they click the voicemail button? I can still hold down the 1 key to dial voicemail but the buttom FC's everytime. On reborn v2
has nothing to do with dialer and everything to do with the rom, go to the rebon thread, theres solutions for this
I'm working on Reborn V2.1 version. Somethings are not changing as with prior versions. According to the Reborn Rom changelog Visual voicemail is not supported and you have to use google voice.
Was wondering if u were still wotking on this. I am using this dialer theme with Reborn v2.1 & Sprint VVM and no problems except the green highlight on the tabs on the top.
I was wondering if this would work with the Retouched Theme, I think that would look sweet. But I dont know if I flashed this after flashing the Retouched theme if it would remove the noIQ patch or mess up anything else...
If I may, yes it should work fine and won't change the yellow and black buttons up top. It also will not affect the noIQagent tweak. What it will do is swap the reTouched "special guest " picture in your contacts with the one in this file. Which is also awesome IMO.
Sent by Tapatalk ----- Optimus s
Reactions: Warlord721
:cool:Thanks for the lettin' me know... Flashed them both and it looks friggin sweet! the bluecontactsdialer theme looks better too with the yellow outline instead of the big green highlight on the tab... Thanks! Your work is much appreciated!
I did like the "special guest" too but the 'evil' little dude just sets it off! Plus its still cool to see him in the notification dropdown too! :cool:
maybe you could make a zip that doesnt have the voicemail button for the ones on here running the ReBorn ROM......Love it either way, but would be better if vm button was removed cant use it anyways. Just a suggestion.
That would be appreciated I had been planning on trying to figure out how to do this myself but unfortunately I've been distracted as of late.
For Reborn Rom 2.1. Here you go. Still a few greens I need to find. And do the all black buttons later.
attachment.php
qpss
