[Theme][Port][Com ROM 2.0]Glowing Blue Style Version 4.0 Jun, 17 2011
Haven't flashed this yet, but my guess is they aren't a CWM flashable zip, but rather just a normal zip. Extract using a file explorer or on your PC, then use them from there
you are correct. maybe i should put that in the op. this is like the 4th person to try that.
Beautiful Widgets... might not be what you use, but your clock, it's HUGE lol just a personal preference. Some of us youngsters still have our eyesight ;)
welp some of us old goats used to have good eye sight, now we think what we see and hope its what we thought it was..
yea the screens looked good to me ..i may flash it later ,,i am reloading my ph as we speak.
Woohoo i figured it out!!! Thank you (GUNNERMIKE) i love your theme, this is my them for good unless you come out with a good one lol. Thank you so much.............
themed
i am gonna do some more work on it later today. im learning as i go. i have to make some icons that the original theme didnt have. that will be a big challenge, im not very good with photoshop...yet. i geuss i will have to learn. i have a new appreciation for all the guys who theme.
Ok son i am hopeing i get yer theme install ..
so far i havent flashed a theme,,so this will be my first, but the darned screens sold me, i realy like them and THX for yer work.
Just another note of encouragement, it is really coming along nicely.i really wish that I could just throw up those notification bar icons, they really rock.
Keep going, the whole thing looks like it is gonna be awesome when done.
Ok don't know if I am the only one but I have reflashed a few times and I even redownload it and didn't fix it but the 1.2 the top bar is really black but if I go to other apps it the color of what the app is like now its gray. Also if I pull it down the date shows up but its wrote over the lookout and the temp of my weatherbug. Just wanted to let you know if u need more info just let me know I will try to help.
Sent from my SCH-I500 using Tapatalk
No, not the only one. Having same issue with the color of the top bar taking on the color of whatever app I enter so I cant see the time or date, Doesn't seem to effect the icons though.
Ok, Stoopid question time again...
If I am running launcher pro plus..does the them replace the lauacher? or is the theme an overlay on the luancher? A brief explanation would be appreciated.
What say you, Mikey?
There are no stoopid questions, just stoopid peop.....uh, me.
With all of the other themes I have tried, themed apps replace the standard ones. This usually makes it impossible to upgrade the app when new release of that app come out. However, it simply depends on whether the app is upgraded frequently or not.
Example: Launcher Pro and the Android Market are infrequently updated, so it presents no problem for these apps.
Google Maps and Nav, on the other hand, have been getting a lot of updates recently, so those apps could be problematic if themed.
All this being said, I prefer non-themed apps, but there is nothing really systemically wrong with themed apps.
Sent from my Froyo Fascinate using Tapatalk.
Looks good dude everything going smooth love the bootup video my son found it funny too hes 2 so he was saying bobot peeing. The 4 tab lockscreen force close on me.but its working good now.
lol, its my favorate bootanimation. let me know if you have any more trouble with the six lock and i will release a 5 lock version if it becomes a problem.
Bump....
I would really like to load this theme, but I need to know. The impacts of theming. I did a RTFM on JaeKar's thread, but it didn't answer my question.
Anybody?
Mike
Bump....
Anybody?
Mike
Theme usually replaces or overlays the launcher. Superclean 2.9.2 comes with the AOSP launcher, but when I flashed NitroVivid, I now have LauncherPro. If you have upgraded to LauncherPro 0.8.4.1 through the market, I could see running any theme that has an earlier version of LP possibly creating a problem. Not sure though. I know running any theme with LP 0.8.3, you cannot update to LP 0.8.4.1 in the market. Update will not install.
Bummer ...
Thanks LS..I am running. 8.4.1
Even though this is my personal phone, it is mission critical for my job. I can't afford a brick, so I am very careful what I do...
I hate to do this, but I really like the blue wallpapers. I have extracted them to my SDcard (they are .jpgs) When I click on a spot on my screen and click on wallpapers, i look in both live and not live and I'm not seeing them. Forgive me for being stupid, but how do I get them to show up there?
Edit. NM, it's not in live or regular, it's in gallery. I'm stupid (shhh no one else knows!)
Algarañaz
