[THEME] Post Your Custom Themes Here
Does the stock font flash zip require the theme to be flashed beforehand, or is it the theme without the font change?
The stock-font.zip only changes the font.
So, flash the theme, then the font.zip
Sent by Tapatalk ----- Optimus s
Thanks again for posting the old font. I really like the font you selected in many apps & screens. It's nice that it's a little smaller so more horizontal text was displayed, but apparently my eyes are aging.
I'm glad others have asked for the font though - I felt like a whiner when it was just me! Great theme.:cool:
Hey no problem, and you weren't whining at all. All questions and suggestions are welcome here.
Hey guys
Anyone missing the minus key from the stock calculator?
Sent from my dentists office in a pool of blood.
Reactions: jondevere
Hey guys
lmao.. yes i am as well... not sure if it was just forgotten or was like that in the original Reborn. Ill see what i can find but i bet just a simple fix is needed on the theme.. good call
Ok, just verified. The .png file that was for the minus key was accidentally removed, or filled. Easy mistake and have been talking to jstntp about the issue. He told me that he is gonna fix that asap. The function of the minus key does still work tho. Thank you for the heads up on the issue. I never use the calc app. :p
My minus key blank area only adds, it wont minus.
its like the mapping area was taken over by the + button
got to go hes comming at me with some silver prybar looking thing.
Not for me. Although blank, the minus button works correctly and the plus works correctly.
I'll fix it in a little while. Sorry guys.
Ok, it is the font change I included in the theme that is causing the minus button to not display in the stock calculator program. So, if you flash the stock-font.zip from the OP, it will show again. Either way, the button functions as normal. I don't use the stock calc. So I missed that. RealCalc from the market displays and functions as it should with the custom font included in the theme. I may look into fixing this, but since there is an easy alternative, I may not.
Thanks for all the positive posts and I'm glad everyone likes the theme.
Mix between darkhorse, and several others...
So, I'm unsure if anyone would be interested in my modified theme... (or if this is even the right place to share it)...
Basically, I've been running this for my own use for a while, and thought I'd share. Basically it uses some of the icon's from darkhorse theme, and some from the theme kitchen (asked for permission over on XDA some time ago... for the darkhorse theme) and the modified power background posted earlier in this thread... I like the change in icon's... I can provide the bee background too if you're interested...
(and if I'm wrong about things I'm certain someone will let me know.)
(revised) tweaked-reborn-theme-signed.zip
Much thanks to jstntp for figuring out why this wasn't flashing right... sometimes I hate case sensitivity...
Thank!
Looks good. Back when I ran ThunderRom I used the DarkHorse theme.
I'm glad to see people out there modding up themes for Reborn, it's a great Rom and it deserves more people having a go at it!
nothing happened when I flashed this. What did I do wrong? It worked for the other retouched theme.
I know I read this somewhere, but can't seem to find it. I have no idea what the "noIQagent" tweak does. Is it a good idea to flash it after I flash this theme? Thanks!
For the most part the IQagent is 'deactivated' and doesn't really do much on the device apart from use battery.
The capabilities of it are a little creepy to consider and I won't go into extreme detail but if you look it is explained in full on the xda forums, I don't have the link right now.
Basically the IQ agent is designed as a usage tracker, only problem is it has the ability to track pretty much everything. As I said though the logging side of it is deactivated and therefore it doesn't serve much purpose.
The real annoyance is that background processes still eat the battery for absolutely no reason.
This theme and most already remove the IQ agent for you so you don't need to worry about doing it in a separate flash.
Reactions: 64fairlane
Thanks so much for your very informative post.
tota
