[THEME] Post Your Custom Themes Here
Scifan i still cant get your tweeked theme to work, i installed the one from your updated post using 7zip, is it because I am flashing over retouched?
So, I'm unsure if anyone would be interested in my modified theme... (or if this is even the right place to share it)...
Basically, I've been running this for my own use for a while, and thought I'd share. Basically it uses some of the icon's from darkhorse theme, and some from the theme kitchen (asked for permission over on XDA some time ago... for the darkhorse theme) and the modified power background posted earlier in this thread... I like the change in icon's... I can provide the bee background too if you're interested...
(and if I'm wrong about things I'm certain someone will let me know.)
(revised) tweaked-reborn-theme-signed.zip
What launcher r u runnin?
Still doesn't work for me either.
The first problem was failing to zip the files properly - zip file needed to root a directory below where I'd started it... the 2nd problem was that I had the System folder capitalized rather than all lower case (thanks to jstntp for figuring that out)...
It'll work now... sorry for the confusion..
link
Reactions: jklph
link
simply beautiful. amazing! thank you for the nice work. :)
I thought I'd share this cool boot animation (credit to Fusion0306 @ android.modaco.com)
To install:
1) save this file: http://dl.dropbox.com/u/10065194/bootanimation.zip
2) backup first:
adb pull /data/local/bootanimation.zip c:\temp\
3) install:
adb push bootanimation.zip /data/local
adb restart
4) wait for bootup and enjoy!
Reactions: jstntp
I'd missed a couple of icon's previously... I also changed some additional icons as well... including blue smiley faces... set the bee as the "default" background image... ;)
There are a couple of additional things I'd like to do, but am not feeling so excited about recompiling the apk... (my phone wasn't happy with the results the last time I tried...)
revised tweaked theme
Please gather all the themes spread throughout the thread and put them in the OP like Nick7 does with his so they are easily available and can be compared side-by-side. Great work, all.
If you would have taken two seconds to look at the OP before you posted this, you would have seen that this has allready been done. There are a total of two custom themes in this entire thread right now. If thekraven, or anyone else for that matter, would like to post his/her theme here, I will be happy to post screenshots and link to it from the OP.
what the best way to change the wallpaper so it is cropped correctly? its either too cropped or too spread out for me.
I basically just grab the bottom center and pull it down as far as I can... that's what you see in my screen caps. No, it's not the "full" image, but it works.
I revised this about 4 times and still am not completely satisfied but hey. Lets call it SonicBlue theme. SonicBlue Theme
Currently has Icons, bright power controls, blue pop ups and pull down. Will make some more later if ppl like it.
Sweet !!!! I will link to your post from the OP. Also if you want to post some screenshots. I'll link those too.
Sent by Tapatalk ----- Optimus s
tota
