[THEMES] Optimus s Gingerbread Themes
Re: [THEMES] Optimus s Gingerbread Themes -- 10/23/11
What is going on? i'v been running gRom 2.2, and have been using go launcher for themes while waiting for CM7.. I really like the new redRum theme.. after wiping and flashing, i boot to the animation and stuck there.. tryed twice now, been sitting for ~10minutes...
Restore your backup, then try it without wiping anything.
Reactions: jmrwbilly
thanks, will do as soon as I am done... Thanks for all your help. I hope to come up with a nice theme soon.
got it to work.. luckly i had a backup from about week ago when i checked out OptiRom.. flashed theme...LOOKS GREAT!! still curious what is means if there is a ~ infront of the # in adb shell...
really? it wouldn't accept the su command when the ~ was present
Sorry, Misread your question.. the ~ doesn't mean anything, Its just there to tell you its a new command.
thanks for all your help... but I can't seem to locate a few images... on the notification page, the background underneath the images themselves, and the battery... Where can I find these?
framework-res.apk
Thanks for posting the stock ginger bread theme, Its gna be the base for all of my themes :D
Awesome. Here's a tip for you though. Take reTouched and put all the stock gingerbread pngs in it then build off that. The reason is I modded the xml and smali files in reTouched to allow transparency in areas that you can't get it with the stock theme. ;)
i guess no husker theme, oh well :-$ , retouched it just fine :)
Is there a way to remove the picture in the notification drop down in the reTouched theme? I already use the mascot on my wallpaper.Thanks for all your hard work.Your themes are all great
Thanks for the Help dude... Maybe once I can learn the basics we could work together on some themes :D
mnundy1
